> Brake line plastic clips?
Chris914n6
post Feb 19 2026, 04:32 PM
Jackstands are my life.
Maybe I'm calling them the wrong thing but I can't seem to find factory repro or generic fit clips to hold the hard brake lines to sheetmetal (engine bay in particular).
JeffBowlsby
post Feb 24 2026, 01:11 PM
@DennisV
The fuel line clip is 2-pieces, a body and a separate solid ~5mm dia. rod, both of Nylon. The rod inserts into the hole centered in the clip body, and I see subtle bumps inside the hollow tube extension of the hole on the back side of the clip to friction hold the rod in place, once the rod is fully inserted. The two parts are a close tolerance friction fit. The plunger seems to be a uniform OD, not tapered. The clip body holds two fuel lines in parallel. The clip in the photos is broken, but it should have symmetrical arms.
If this cannot be replicated, can something functionally similar be developed and printed?
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: JeffBowlsby
- Lo-Fi Version Time is now: 13th May 2026 - 06:01 PM
