| pbanders |
Feb 26 2026, 11:32 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 988 Joined: 11-June 03 From: Scottsdale, AZ Member No.: 805 Region Association: Southwest Region |
Example of using Perplexity to understand how the MPS operates. Not perfect, but gives you an idea of what can be done.
https://www.perplexity.ai/search/how-does-t...ue3_8lIh9rqNQ#2 This was the query: "How does the pressure sensor used in the Bosch D-Jetronic fuel injection system work? Be detailed in describing how it operates at idle, part-load, and full-load conditions." To improve on the quality of the response, you can combine Perplexity with NotebookLM to cherry-pick the sources you want to use for the topic. This prevents unreliable sources being used, and extends the types of sources. This concept can be used for a huge number of topics. |
| Superhawk996 |
Feb 26 2026, 12:42 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,727 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I know AI is unstoppable . . .
But it is hilarious that it’s just scraping jetronic.org and that you have to coach it. Frankly it should also be scraping your site. Interesting attempt though. (IMG:style_emoticons/default/beerchug.gif) |
pbanders AI Tools for D-Jetronic Instruction Feb 26 2026, 11:32 AM
worn
Example of using Perplexity to understand how the... Feb 26 2026, 08:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th February 2026 - 04:51 AM |
