| Chad911sc |
Feb 24 2026, 10:32 AM
Member ![]() ![]() Group: Members Posts: 328 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
Finally put the short block back together this past weekend! (IMG:style_emoticons/default/beerchug.gif)
This is for the next guy who wants to put an o-ringed oil pump into their motor. I purchased one from low budget VW and it had the correct circumference, but sat too deep into the type 4 case. It bottomed out against the cam, and the o-ring groove was inside the case instead of the case bore ( Pic 1,2). So I dropped the idea of the o-ring pump and just ordered a CB performance pump built for the type 4 engine. I once again measured the circumference against the case and it was good. But, after looking at it closely in the case I noticed that the oil intake once again didn’t line up properly, and it only had a pubic hair’s worth of metal riding on the case. It was sure to suck air, even though it was the correct circumference (Pic 3). So I ended up going to the local water jet shop and took one of the oil pump gaskets with me for the shape. They cut out a spacer from 1/8 inch aluminum and it worked perfectly. Now the intake port lines up correctly and the o-ring sits inside the case bore as it should (Pic 4). Forgot to take a picture of the spacer, but it looks like this one from the German Supply kit.….(Pic5) Attached thumbnail(s) |
| Superhawk996 |
Feb 27 2026, 12:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,122 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Love the thread title: Type 1 oil pump revisit, For the last time
(IMG:style_emoticons/default/laugh.gif) Nice photos documenting some of the concerns. |
Chad911sc Type 1 oil pump revisit Feb 24 2026, 10:32 AM
stownsen914 Thanks for sharing. I had this question about usin... Feb 26 2026, 11:12 AM
Chad911sc No the CB performance one is not an o-ringed pump.... Feb 26 2026, 01:28 PM
stownsen914 Thanks. When you say the CB pump has a smaller sea... Feb 26 2026, 03:05 PM
Chad911sc If you look at picture #3, you can see what I’m ... Feb 26 2026, 03:37 PM
Jack Standz Photo shows a cut-in-half old Type 1 oil pump hous... Feb 27 2026, 11:40 AM
Jack Standz Photo shows a Type I oil pump with o-ring modified... Feb 27 2026, 11:41 AM
friethmiller I'm definitely going to be doing this type of ... Feb 27 2026, 01:58 PM
cgnj Unearthing this post. This may be one stop shoppin... May 15 2026, 10:26 AM
stownsen914 Ah so someone does make a spacer! Thanks for s... May 16 2026, 06:59 AM
Chad911sc I have not seen any for sale online…..I looked.
... May 16 2026, 11:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th October 2026 - 12:30 PM |
