| Dustin |
Feb 16 2026, 06:16 PM
Member ![]() ![]() Group: Members Posts: 117 Joined: 19-August 10 From: Woodland Hills, CA Member No.: 12,072 Region Association: None |
I put my car back together recently. I think everything is as it should be. Yesterday I started it and it ran for like 10 seconds and then died. I wasn't able to give it gas cause I wasn't fully seated in the car.
Today when I got in the car the generator light was on. I started it and it ran for like 30 seconds then died. The gas pedal seemed unresponsive. Now it will crank but makes no signs of sparking. I'm only getting 7.5 volts on the + side of the coil with the ignition on. |
| emerygt350 |
Mar 8 2026, 05:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,511 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
You say the timing light isn't flashing? Can you verify spark?
Dustin 76 914 crank but no start Feb 16 2026, 06:16 PM
Superhawk996 Address your low voltage at the coil issue. What ... Feb 17 2026, 12:09 AM
wonkipop
Address your low voltage at the coil issue. What... Mar 6 2026, 11:39 PM
Dustin What happens if my injectors are plugged in backwa... Feb 19 2026, 04:56 PM
Dustin I think they were plugged in backwards. I flipped ... Feb 19 2026, 05:57 PM
emerygt350 Doesn't matter which way. Something else is u... Feb 19 2026, 07:59 PM
Dustin I still haven't resolved this.
Sometimes when... Mar 6 2026, 07:56 PM
Dustin I think I got it. I had to map out the circuit. I ... Mar 7 2026, 01:20 AM
emerygt350 If that doesn't cure it, check your grounds. ... Mar 7 2026, 07:24 AM
Dustin It's still not starting.
I am getting a dwell... Mar 7 2026, 03:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 09:41 AM |
