> Chasing a Ghost in the Machine, It’s been a year and I thought I had it.
mgphoto
post Feb 10 2026, 11:46 AM
"If there is a mistake it will find me"
About a year ago my usually good running engine began to stumble, slight backfire through the exhaust, between 1000 to 3000 rpm. I first suspected an electrical fault, as I would shake wires in the engine compartment and the issue would be gone.
This happened several times with different wires. I decided to tin the ends of the wires attached to the positive battery terminal. This seemed to work, for a while.
I began testing other wires for the D-Jet, I had success with reattaching the TPS connector, for about a day.
I began following a post about a member who had trouble with his 123 dizzy, his issue was related to the D-Jet pulse producing erratic fuel delivery.
OK, spoke with the tech person at 123 in Europe, we could test it using an oscilloscope.
I have a small pocket unit that I can test it with. This past Sunday I decided would be a good time do the test.
My plan was to take the car out for a warm up drive, once around a freeway loop gets my oil temp needle to move.
After exiting the freeway, I stopped at a traffic light and the car stalled, I’m used to that happening sometimes as I have a lightened flywheel, but this was different, like I turned the key off.
I turned the key to restart the engine but it sounded like a rattling chain, I never heard that sound before. I tried the starter again, now it had the typical hot start problem, after a moment I got it to run but the idle was now at 3400 rpm.
Since I could control it I drove it home and began checking simple things like throttle cable, TPS loose, MPS held some vacuum using the suck test.
I’m going to take a closer look at the throttle body.
Anyone have their D-Jet idle jump to 3200 rpm and what was the reason?
Thanks,
Mike
bkrantz
post Mar 9 2026, 06:50 PM
Is starter spray (ether) still a thing? Spray this at different connections and when the engine revs up you found the leak.
mgphoto   Chasing a Ghost in the Machine   Feb 10 2026, 11:46 AM
brant   Return spring maybe   Feb 10 2026, 11:50 AM
76-914   spot weld failure on the clutch cable tube? :beer2...   Feb 10 2026, 12:14 PM
Dave_Darling   A 3200 RPM idle is an air leak. A *BIG* one. Che...   Feb 11 2026, 01:28 AM
JeffBowlsby   The MPS mouth suck test is completely irrelevant, ...   Feb 11 2026, 08:42 AM
pbanders   Good advice from all. I've found that finding ...   Feb 11 2026, 01:42 PM
mgphoto   Big air leak! Major clue, going to check it in...   Feb 12 2026, 09:41 PM
mgphoto   Ok, I’ve gotten this far. I removed the air filt...   Mar 9 2026, 12:32 PM
914sgofast2   I would suspect your AAR valve has gone bad and ne...   Mar 9 2026, 12:47 PM
emerygt350   that t that the pcv goes to on a 73 is often the c...   Mar 9 2026, 12:47 PM
bkrantz   Is starter spray (ether) still a thing? Spray thi...   Mar 9 2026, 06:50 PM
76-914   Disconnect everything from the vacuum side except ...   Mar 9 2026, 09:10 PM
mgphoto   Don’t see the AAR as the issue as it hasn’t wo...   Mar 11 2026, 06:04 PM
emerygt350   Don’t see the AAR as the issue as it hasn’t w...   Mar 12 2026, 09:40 AM
mgphoto   Don’t see the AAR as the issue as it hasn’t ...   Mar 12 2026, 01:25 PM
rjames   Check the Plenum too. They rust out from the insid...   Mar 12 2026, 09:48 PM
jim_hoyland   I had an air leak caused from a faulty 3-way conne...   Mar 13 2026, 05:56 AM
mgphoto   Ok, I pulled the hoses on the plenum, there is a r...   Mar 16 2026, 01:14 PM
rjames   Ok, I pulled the hoses on the plenum, there is a ...   Mar 17 2026, 04:47 PM
- Lo-Fi Version Time is now: 15th April 2026 - 04:16 AM
