| Cvrguy |
Mar 8 2026, 02:36 PM
Newbie ![]() Group: Members Posts: 24 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
The essential question is how the bushings function. Do they regulate suspension movement in shear or are they solely serving a cushioning function? If it is the latter, a high quality non-petroleum based grease should function well while also serving a corrosion resistant role as well. Thoughts?
| Arkady |
Mar 10 2026, 12:26 PM
Newbie ![]() Group: Members Posts: 31 Joined: 13-May 22 From: Home, PA Member No.: 26,545 Region Association: MidAtlantic Region |
I watched a local bicycle shop install rubber(ish) handlebar grips on a mountain bike. They used hair spray. This provided lubrication while sliding the grips over the bar. Soon afterward the 'slipperiness' disappeared and the grip stayed put. So, I tried this method on my bike. Years later it still is securely in place.
Not sure if this is applicable here, though. |
Cvrguy front suspension bushing installation alternative to liquid soap? Mar 8 2026, 02:36 PM
Ninja The bushings twist!
They should stay locked t... Mar 8 2026, 04:38 PM
Cvrguy
I watched a local bicycle shop install rubber(ish... Mar 10 2026, 02:23 PM
brant
I watched a local bicycle shop install rubber(is... Mar 10 2026, 02:30 PM
Cvrguy
[quote name='Cvrguy' post='3248605' date='Mar 10 ... Mar 11 2026, 10:04 PM
mgp4591
[quote name='Cvrguy' post='3248605' date='Mar 10... Mar 14 2026, 03:16 AM
Ninja The fastest of all of the lubricants I've used... Mar 10 2026, 02:35 PM
mgphoto Astroglide. Mar 11 2026, 05:53 PM
GregAmy Any time I need a lube to do this kind of work, it... Mar 14 2026, 06:04 AM
Front yard mechanic Monkey butt works well Mar 14 2026, 06:50 AM
Front yard mechanic
Mar 14 2026, 10:44 AM
worn
Still gotta love your ava... Mar 14 2026, 06:07 PM
Superhawk996
Detergent won’t actually evaporate, nor glyce... Mar 14 2026, 11:20 PM
Cvrguy When I finally did the installation, it turned out... May 4 2026, 03:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th May 2026 - 11:28 PM |
