| Cvrguy |
Mar 8 2026, 02:36 PM
Newbie ![]() Group: Members Posts: 24 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
The essential question is how the bushings function. Do they regulate suspension movement in shear or are they solely serving a cushioning function? If it is the latter, a high quality non-petroleum based grease should function well while also serving a corrosion resistant role as well. Thoughts?
| Arkady |
Mar 10 2026, 12:26 PM
Newbie ![]() Group: Members Posts: 31 Joined: 13-May 22 From: Home, PA Member No.: 26,545 Region Association: MidAtlantic Region |
I watched a local bicycle shop install rubber(ish) handlebar grips on a mountain bike. They used hair spray. This provided lubrication while sliding the grips over the bar. Soon afterward the 'slipperiness' disappeared and the grip stayed put. So, I tried this method on my bike. Years later it still is securely in place.
Not sure if this is applicable here, though. |
| Cvrguy |
Mar 10 2026, 02:23 PM
I watched a local bicycle shop install rubber(ish) handlebar grips on a mountain bike. They used hair spray. This provided lubrication while sliding the grips over the bar. Soon afterward the 'slipperiness' disappeared and the grip stayed put. So, I tried this method on my bike. Years later it still is securely in place. Not sure if this is applicable here, though. Given that the bushings need to be fixed in position, I am looking for a way to increase the "working time" between installation and when the soap dries out. Would glycerin take longer or slower to set up? I'm not confident that the measurements I took prior to removal will be correct once installed. If they are incorrect, I could end up with too high a "bushing" spring rate. I'm curious as to how the factory did it initially. |
Cvrguy front suspension bushing installation alternative to liquid soap? Mar 8 2026, 02:36 PM
Ninja The bushings twist!
They should stay locked t... Mar 8 2026, 04:38 PM
brant
I watched a local bicycle shop install rubber(is... Mar 10 2026, 02:30 PM
Cvrguy
[quote name='Cvrguy' post='3248605' date='Mar 10 ... Mar 11 2026, 10:04 PM
mgp4591
[quote name='Cvrguy' post='3248605' date='Mar 10... Mar 14 2026, 03:16 AM
Ninja The fastest of all of the lubricants I've used... Mar 10 2026, 02:35 PM
mgphoto Astroglide. Mar 11 2026, 05:53 PM
GregAmy Any time I need a lube to do this kind of work, it... Mar 14 2026, 06:04 AM
Front yard mechanic Monkey butt works well Mar 14 2026, 06:50 AM
Front yard mechanic
Mar 14 2026, 10:44 AM
worn
Still gotta love your ava... Mar 14 2026, 06:07 PM
Superhawk996
Detergent won’t actually evaporate, nor glyce... Mar 14 2026, 11:20 PM
Cvrguy When I finally did the installation, it turned out... May 4 2026, 03:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th May 2026 - 11:29 PM |
