| ctc911ctc |
May 30 2025, 07:25 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,389 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
1970 914-6 all stock
All, I am down to the last thing for this engine re-fresh: CARBS They seem to be in very good condition and since they are missing the Porsche factory mark I am guessing that they were 'cored' on a rebuild sometime prior to my ownership OR Are 914-6 carbs NOT market like 911 carbs are??????? Anyway, I have not gone too deep since they are in great shape - the gaskets seem good, the floats are the brass kind but in perfect shape, the bowls are very clean,,,,,, Can I get some direction on: 1. what to look for in a recently rebuilt carb 2. where is a good reference for setup prior to installation Any other opinions would be well received, Thank you Teeners YES I KNOW (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Pictures will be added later |
| ctc911ctc |
Mar 11 2026, 04:06 PM
SORRRY - pictures are in the Preview but not in the post (IMG:style_emoticons/default/WTF.gif) I over analyze everything! Over-Analysis working theory If you are reading this you are up to speed as to what I am chasing. I cannot get the car to start when cold (60 degrees F or hotter) without 10-15 tries. Each try is the same. Idle handle - full ON PUMP the gas peddle twice Grind the starter Pump the accelerator Engine immediately starts and then dies. Repeat 10-15 times Then engine will start to stay running Once it is warm and starting it is running smooth, occasional pop and also Smells VERY rich, VERY, VERY rich This makes little sense too rich and I need to pump it to get it started? Perhaps the downflow of the carbs (veturi effect) is so weak that I need to keep the fuel pumping from the accel-pump circuit since the jets are not supplying the fuel? NEXT Looking at the spark plugs, I see that one side is VERY rich, the other is not. IDEA Perhaps once side the carb is working properly (RICH) and the other is running LEAN and the leanness or fuel starvation is causing this hard to keep started effect? Plugs 1->6, L->R Attached thumbnail(s) |
ctc911ctc WEBER 40 - 914-6 or 911T Carbs May 30 2025, 07:25 PM
rick 918-S :agree: :ttiwwp: :driving: May 30 2025, 09:00 PM
euro911 See if you can find a copy of this factory Weber T... May 30 2025, 09:28 PM
sixnotfour What Porsche marking are you referring to ?
they... May 30 2025, 10:21 PM
porschetub
All,
I am down to the last... May 31 2025, 12:05 AM
930cabman clean em up and run em May 31 2025, 06:01 AM
rgalla9146 Cary
When I worked on the car 25 years ago (... May 31 2025, 08:42 AM
ctc911ctc
Cary
When I worked on the car 25 years ago ... May 31 2025, 04:32 PM
brant I’m not aware of any aftermarket 3 barrel carbs ... Jun 1 2025, 07:08 AM
Graydingo
Can I get some direction o... Jun 1 2025, 08:29 AM
brant Don’t forget to measure and adjust accel pumps a... Jun 1 2025, 08:57 AM
914Sixer China now making replacement carbs. Jun 1 2025, 09:46 AM
73-914
:lol4: :ro... Mar 12 2026, 11:25 AM
ctc911ctc Here are the pictures I promised, first, here is t... Jun 1 2025, 07:22 PM
ctc911ctc ..................Continued.................
Insi... Jun 1 2025, 07:25 PM
sixnotfour Not Even Italian....
Those are from PMO way back w... Jun 1 2025, 07:41 PM
sixnotfour :shades2: Jun 1 2025, 08:19 PM
sixnotfour :shades2: Jun 1 2025, 08:20 PM
ctc911ctc
:shades2:
Almost matching…………huh…….... Jun 1 2025, 08:24 PM
porschetub
:shades2:
Almost matching…………huh……... Jun 4 2025, 09:13 PM
mskala I am not an expert but I remember hearing a lot of... Jun 5 2025, 06:16 AM
brant I don’t know what stoddard was doing
Assume the... Jun 5 2025, 06:33 AM
mate914 I had Paul Abbot(sp) convert a set of carbs to IDS... Jun 5 2025, 09:20 AM
brant
I had Paul Abbot(sp) convert a set of carbs to ID... Jun 5 2025, 09:32 AM
ctc911ctc ****UPDATE****
Sooooo.......it would seem that on... Jun 5 2025, 10:10 AM
rgalla9146 Those are replacement newer production carbs.
... Jun 5 2025, 11:34 AM
mskala You can borrow my float level gauge and I have som... Jun 5 2025, 02:00 PM
Graydingo Yeah those aren't PMO, Carter was making those... Jun 5 2025, 03:51 PM
sixnotfour
Yeah those aren't PMO, Carter was making thos... Jun 7 2025, 08:30 AM
DennisV
Are 914-6 carbs NOT market like 911 carbs are????... Jun 5 2025, 04:37 PM
sixnotfour "S" is Best.. Jun 12 2025, 06:48 AM
sixaddict Just an FYI
I have a set of original set of 914-6... Jun 12 2025, 07:11 AM
sixnotfour He has it handled Im just messin around... Jun 12 2025, 07:20 AM
sixnotfour :beer2: Jun 12 2025, 08:23 AM
ctc911ctc RE: WEBER 40 - 914-6 or 911T Carbs Feb 15 2026, 02:47 PM
ctc911ctc
:bump: Mar 10 2026, 07:35 PM
930cabman One side very rich should provide a clue to what... Mar 11 2026, 04:38 PM
ctc911ctc Fixed the pictures within the last post - BUMP Mar 12 2026, 07:02 AM
Superhawk996 www.914world.com/bbs2/index.php?showtopic=376092... Mar 12 2026, 07:38 AM
930cabman I'd go back to the basics and check everything Mar 12 2026, 02:11 PM
rudedude If you have had them all apart you shouid know wha... Mar 12 2026, 05:36 PM
Superhawk996
If you have had them all apart you shouid know wh... Mar 13 2026, 06:35 AM
gereed75 Just curious - does it seem to start/ run better w... Mar 13 2026, 11:40 AM
930cabman
Just curious - does it seem to start/ run better ... Mar 13 2026, 04:05 PM
sixnotfour :blink: Mar 13 2026, 10:56 PM
sixnotfour back to square 2.. square 1 check that when #1 is ... Mar 13 2026, 10:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 09:18 PM |
