| Cvrguy |
Mar 8 2026, 02:36 PM
Newbie ![]() Group: Members Posts: 24 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
The essential question is how the bushings function. Do they regulate suspension movement in shear or are they solely serving a cushioning function? If it is the latter, a high quality non-petroleum based grease should function well while also serving a corrosion resistant role as well. Thoughts?
| Front yard mechanic |
Mar 14 2026, 06:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Monkey butt works well
| worn |
Mar 14 2026, 06:07 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,573 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| Superhawk996 |
Mar 14 2026, 11:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,831 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Detergent won’t actually evaporate, nor glycerin. Glycerin is used all the time within the automotive industry to assemble press fit rubber bushings. It is used by the OEMs as well as the supply base. The bulk of the of glycerin is squeezed out by the press fit, the remaining thin film between the press fit parts is absorbed by the rubber (usually ~24 hours) you will find the bushing grips very tightly and will not rotate. Glycerin without exposure to water becomes tacky & sticky. External squeeze out will be washed away by water. Glycerin is a good assembly lube for rubber bushings. If you are queasy about the wife or your buddy’s finding Astroglide or KY-Jelly in your shop, here’s a commercial non-glycerin product specifically intended for bushing and rubber hoses. ![]() https://ipcol.com/wp-content/uploads/WhichP80_ePaper1710.pdf |
Cvrguy front suspension bushing installation alternative to liquid soap? Mar 8 2026, 02:36 PM
Ninja The bushings twist!
They should stay locked t... Mar 8 2026, 04:38 PM
Arkady I watched a local bicycle shop install rubber(ish)... Mar 10 2026, 12:26 PM
Cvrguy
I watched a local bicycle shop install rubber(ish... Mar 10 2026, 02:23 PM
brant
I watched a local bicycle shop install rubber(is... Mar 10 2026, 02:30 PM
Cvrguy
[quote name='Cvrguy' post='3248605' date='Mar 10 ... Mar 11 2026, 10:04 PM
mgp4591
[quote name='Cvrguy' post='3248605' date='Mar 10... Mar 14 2026, 03:16 AM
Ninja The fastest of all of the lubricants I've used... Mar 10 2026, 02:35 PM
mgphoto Astroglide. Mar 11 2026, 05:53 PM
GregAmy Any time I need a lube to do this kind of work, it... Mar 14 2026, 06:04 AM
Front yard mechanic
Mar 14 2026, 10:44 AM
Cvrguy When I finally did the installation, it turned out... May 4 2026, 03:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th May 2026 - 11:28 PM |
