| mcericmc |
Mar 15 2026, 10:43 AM
Newbie ![]() Group: Members Posts: 8 Joined: 30-June 21 From: Texas Member No.: 25,681 Region Association: None |
I could use some help with a DPD aftermarket A/C system I bought years ago, but never got around to installing because of my wife's health problems. I live in Texas, so A/C is a necessity during the 8 months of summer here.
I'm looking for pictures of the compressor mounted to the engine and pictures of the mounting bracket. I think I might be missing part of the bracket itself. I realize how slim the chances of finding any info is since these systems were kind of rare, but any help or leads to information would be greatly appreciated. Thanks. |
| 914Sixer |
Mar 15 2026, 02:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,434 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
There was another version that used a top mount where the later air pump mount was. No sheet metal cutting in engine compartment. No pictures though
DLee makes AC kit |
| Chris914n6 |
Mar 15 2026, 08:36 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,527 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
It used the off-the-shelf Sanden mount with a couple pieces welded on to mount to the fan shroud. It uses a custom machined pulley extension that bolted to the crank/fan like the smog pump setup.
My understanding is the modern Sanden comp is small enough to not need the body side shroud/seal cut into. There was another version that used a top mount where the later air pump mount was. No sheet metal cutting in engine compartment. No pictures though DLee makes AC kit |
mcericmc Aftermarket A/C compressor bracket Mar 15 2026, 10:43 AM
Literati914 I'm not sure if this is the DPD system or whic... Mar 15 2026, 12:06 PM
mcericmc
I'm not sure if this is the DPD system or whi... Mar 15 2026, 05:36 PM
Ninja That is the first decent side mount system I'v... Mar 15 2026, 02:28 PM
Literati914
I'm not sure if this is the DPD system or wh... Mar 15 2026, 07:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 10:29 PM |
