> Wiring new fuel pump for carb conversion
mb914
post Mar 16 2026, 11:48 AM
Hi All,
I recently installed an engine with carburetors on a 2056. I am trying to use the stock FI wire to power the pump. I read where you need to jumper a cable from pin 30 to 87 on the fuel pump relay. I did that but I am getting constant power to the pump when the key is turned off. Any tips on how to wire the pump so that it only turns on when the key is turned on?
GregAmy
post Mar 16 2026, 12:16 PM
Circuit 30 is direct to the battery, so no surprise there. Instead, leverage the stock fuel pump relay.
Circuit 85 is keyed power and Circuit 86 is the solenoid ground to the computer. If you ground the Circuit 86 wire coming from the relay plate, wire III on the T4b plug, then the fuel pump will only be energized when the power supply relay is energized, thus only with the key on.
Do note that one of the safety features of the stock system is that it will not energize the fuel pump if the engine is not running. So, for example, your fuel pump turns off in a crash and you're upside down with the engine stopped but have not yet turned off the key.
You lose that protection when you have your fuel pump on with the key on.
- Lo-Fi Version Time is now: 17th March 2026 - 04:24 AM
