| Literati914 |
Mar 13 2026, 01:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,379 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I removed the engine tins from my 1.7 to clean and paint, while also degreasing the engine and transmission. I'm thinking I'll re-seal anything that's convenient to do-so while I'm here. There was an accumulation of baked on oil under the tins on top of the cylinders, not so much under (oil return tubes seem fairly well sealed and clean).. what does that usually imply, if anything?
| 914sgofast2 |
Mar 16 2026, 01:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 811 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Check the oil pressure sending unit for leaks and replace it. Replace the o-ring seal on the distributor shaft body. That o-ring is usually rock hard on most of the dizzies I have removed and isn't sealing anymore.
And since the engine is out, I would replace the oil cooler seals and the front crankshaft seal, as well as the rear main seal. Also replace the valve cover seals because it is so much easier to do with the engine out of the car. Obviously replace the seal/o-ring of the taco plate on the bottom of the engine, as well as replacing the two copper washers which seal the nuts of the taco plate. |
Literati914 Re-seal Engine after Clean Up Mar 13 2026, 01:37 PM
mepstein In general, just normal for an air cooled engine. Mar 13 2026, 02:45 PM
bkrantz Check the cork seal under the oil filler "tan... Mar 13 2026, 07:42 PM
Literati914 OK, I'll check that cork seal, thanks.
The o... Mar 13 2026, 09:28 PM
porschetub
The ... Mar 15 2026, 01:03 PM
Jack Standz If you're going to have the oil cooler cleaned... Mar 15 2026, 04:28 PM
porschetub
If you're going to have the oil cooler cleane... Mar 16 2026, 02:08 PM
Literati914
If the motor is out ,I recommend you remove the c... Mar 15 2026, 07:18 PM
Chad911sc Just finished putting my engine back together last... Mar 16 2026, 01:01 PM
Jack Standz As @Chad911sc mentioned, it required a minute o... Mar 16 2026, 04:28 PM
ctc911ctc I would replace all of the pushrod tube seals as w... Mar 16 2026, 04:53 PM
Literati914
Transmission leaking? :shades2:
Pictures?
... Sep 2 2026, 11:51 AM
HFC3 It’s a perfect thread for where I’m at in my r... Sep 2 2026, 12:18 PM
Literati914 ^^ I cleaned the engine and transmission a little ... Sep 2 2026, 02:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd September 2026 - 08:33 PM |
