| 75ninefourteen |
Mar 16 2026, 01:16 PM
Newbie ![]() Group: Members Posts: 25 Joined: 3-October 25 From: Austin, TX Member No.: 29,016 Region Association: Southwest Region |
I've been trying to figure out what model this gauge was originally. So far in searching I've seen some close that are out of a 914-6, but have also seen similar marked as 911. Any ideas? I haven't had a chance to pull the gauge to look for a part number yet. I think the sensor for the oil temp is mismatched since it's reading cool.
| 930cabman |
Mar 16 2026, 01:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,540 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I am unable to assist with the gauge, but you may consider checking the low temp reading with a known source, IR or similar
| 75ninefourteen |
Mar 16 2026, 04:40 PM
| porschetub |
Mar 16 2026, 08:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,043 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I am unable to assist with the gauge, but you may consider checking the low temp reading with a known source, IR or similar Thanks for the suggestion. I am planning to check the temp through the oil dipstick tube as a starting point. Good idea should be close enough as reading is from the sump anyway pay to check the "G" wire on the gauge to sender ,most likely you have a duff sender or wrong rating for the same ,cheers |
75ninefourteen What oil temp / fuel gauge is this? Mar 16 2026, 01:16 PM
GregAmy That appears to be a 1970-1972 914/6 combo gauge, ... Mar 16 2026, 02:10 PM
brant The gauge should have a tiny part number in it.
... Mar 16 2026, 03:36 PM
fixer34 The one on my -6 has horizontal lines in the two ... Mar 16 2026, 03:41 PM
914Wes Post the part number. Attached image to show where... Mar 16 2026, 04:09 PM
75ninefourteen
Post the part number. Attached image to show wher... Mar 16 2026, 04:19 PM
914Sixer Look in 12 o'clock position. It is a 914-6 g... Mar 16 2026, 04:09 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 04:24 AM |
