> Ron's 914, High oil temp
Ron914
post Mar 17 2026, 01:42 PM
Hello all,
It's been about 4 months since I passed my smog test and thought I would be on the way to finally be able to drive my 4 year project .
Well I have been enjoying driving it but only for short trips around town because I feel it has a high oil temperature problem . This is after a short drive around town of 30 minutes . A 45 minute drive will bring the needle on the gauge right to the red zone ,which looking at Phil's calibration photo would indicate about 250F , I don't continue to drive once I get to 250F and pull over and let its cool .
Not exactly sure why or if it really is high ( I don't want to damage my new motor ) but I was given a few things to check by the members hers @Superhawk996 , @emerygt350 .
First I checked my oil Temperature sensor to verify type and operation.
It is a VDO 200 C sensor .
I have the later oil gauge . I removed the sensor and placed it in 212F boiling water and it seems within the correct range on the console gauge .
I am using a Efeng turkey fryer thermometer to check against the gauge in console . The thermometer is accurate . The gauge ( apex seems close to the same reading
There was a discussion the other day on this subject with the question of whether missing a cooling tin on bottom of engine could cause the overheating problem @930cabman .
I have the same issue as I have the tin that the shift rod passes through removed because it the shit rod comes into contact with the tin installed and it shifts better with it removed .
Wondering if I should work on getting it reinstalled to help my cooling ?
I have also worked on the cooling flaps /thermostat but will start a new post for those questions .
I saw a comment about the type of oil . It sounds like Synthetic oil might be a better choice for air cooled oil .
I currently have no oil in my motor and was wondering if Mobil Syn oil would be better than putting back in the Valvoline VR1 20-50W ?
burton73
post Mar 17 2026, 02:30 PM
Senior member, and old dude
Ron, Happy that you completed your smog. I just got this oil for my 6 and by Bud, Alan Sobin got the same for his 6. We are changing our cars this week
HIGH ZINK FORMULA conventional oil not synthetic. I have been told that this is the stuff. If you have a different word on Synthetic versus conventional, please tell. I have heard of people getting leaks from synthetic oil.
Best Bob B
Ron914
post Mar 17 2026, 03:08 PM
QUOTE(burton73 @ Mar 17 2026, 03:30 PM) *
Best Bob B
Hi Bob,
When I first filled the new motor with oil I used Castol , used to get it at Wallmart for a good price then it became unavailable and they started stocking this oil . Im currently using Vavoline .
My comment on using synthetic oil was prompted by a comment that it handles high oil temps better than Dino oil . I've done 3 oil changes in less than 700 miles since the rebuild .
Currently I have not put oil back in after pulling the oil temp sending sensor to test it . Just considering the opinions here on Synthetic . I guess I'm just looking for a little insurance as I negotiate this oil temperature problem .
I want to do Oscar's drive in May but not sure if 250 + miles is a good idea yet .
Ron914   Ron's 914   Mar 17 2026, 01:42 PM
930cabman   My 2056 build is going on 4 years, basically stock...   Mar 17 2026, 01:50 PM
burton73   Ron, Happy that you completed your smog. I just go...   Mar 17 2026, 02:30 PM
Ron914   Ron, Happy that you completed your smog. I just g...   Mar 17 2026, 03:08 PM
Ron914   @930cabman I too have a new 2056 motor and have b...   Mar 17 2026, 02:56 PM
Superhawk996   Here is a mystery piece of tin that came in a bo...   Mar 17 2026, 03:18 PM
Superhawk996   Regarding the calibration of your gage. That does...   Mar 17 2026, 03:23 PM
Ron914   Regarding the calibration of your gage. That doe...   Mar 17 2026, 04:04 PM
Superhawk996   Based on your post yesterday it sounds like I do...   Mar 17 2026, 07:14 PM
Ishley   At some point you might want to look into an Air f...   Mar 17 2026, 04:37 PM
Montreal914   Separate topic, but do you have a head temperature...   Mar 17 2026, 04:43 PM
mgphoto   I’ve had temps get really crazy hot trying a hig...   Mar 17 2026, 08:42 PM
infraredcalvin   I have one of these, but have never used it so, if...   Mar 17 2026, 10:20 PM
fiacra   …. As for oil, ugh, plenty of opinions on that...   Mar 18 2026, 08:53 AM
Ron914   …. As for oil, ugh, plenty of opinions on tha...   Mar 18 2026, 10:50 AM
fiacra   :headbang: Right...I forgot you had a 49 state ...   Mar 18 2026, 11:18 AM
emerygt350   Can you check to see if that tin is missing? I ca...   Mar 18 2026, 05:59 AM
emerygt350   I wouldn't be afraid of trying 40 weight or le...   Mar 18 2026, 11:22 AM
infraredcalvin   I wouldn't be afraid of trying 40 weight or l...   Mar 18 2026, 12:44 PM
emerygt350   [quote name='emerygt350' post='3249720' date='Mar...   Mar 18 2026, 02:43 PM
sburns1967   In the first picture I do not see the thermostat c...   Mar 18 2026, 01:43 PM
Ron914   Well I finally was able to get my AFR gauge instal...   May 29 2026, 02:10 PM
FlacaProductions   where is your sensor for the CHT gauge? Under #3 p...   May 29 2026, 02:47 PM
FlacaProductions   Dakota Digital instructions to get from C to F dis...   May 29 2026, 02:51 PM
emerygt350   Did you say your oil temp gauge jumps a quarter wa...   May 29 2026, 05:12 PM
Ron914   Did you say your oil temp gauge jumps a quarter w...   May 29 2026, 05:59 PM
emerygt350   Definitely a problem with the line or the gauge or...   May 29 2026, 06:49 PM
Ron914   Definitely a problem with the line or the gauge o...   May 29 2026, 08:19 PM
Ishley   Pull the spark plugs and post a picture. Number ea...   May 29 2026, 07:20 PM
Ron914   Pull the spark plugs and post a picture. Number e...   May 29 2026, 08:00 PM
5 User(s) are reading this topic (4 Guests and 0 Anonymous Users)
1 Members: gonzo54
- Lo-Fi Version Time is now: 29th May 2026 - 09:25 PM
