| Ron914 |
Mar 17 2026, 01:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Hello all,
It's been about 4 months since I passed my smog test and thought I would be on the way to finally be able to drive my 4 year project . Well I have been enjoying driving it but only for short trips around town because I feel it has a high oil temperature problem . This is after a short drive around town of 30 minutes . A 45 minute drive will bring the needle on the gauge right to the red zone ,which looking at Phil's calibration photo would indicate about 250F , I don't continue to drive once I get to 250F and pull over and let its cool . Not exactly sure why or if it really is high ( I don't want to damage my new motor ) but I was given a few things to check by the members hers @Superhawk996 , @emerygt350 . First I checked my oil Temperature sensor to verify type and operation. It is a VDO 200 C sensor . I have the later oil gauge . I removed the sensor and placed it in 212F boiling water and it seems within the correct range on the console gauge . I am using a Efeng turkey fryer thermometer to check against the gauge in console . The thermometer is accurate . The gauge ( apex seems close to the same reading There was a discussion the other day on this subject with the question of whether missing a cooling tin on bottom of engine could cause the overheating problem @930cabman . I have the same issue as I have the tin that the shift rod passes through removed because it the shit rod comes into contact with the tin installed and it shifts better with it removed . Wondering if I should work on getting it reinstalled to help my cooling ? I have also worked on the cooling flaps /thermostat but will start a new post for those questions . I saw a comment about the type of oil . It sounds like Synthetic oil might be a better choice for air cooled oil . I currently have no oil in my motor and was wondering if Mobil Syn oil would be better than putting back in the Valvoline VR1 20-50W ? |
| Ishley |
Mar 17 2026, 04:37 PM
Member ![]() ![]() Group: Members Posts: 350 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest
At some point you might want to look into an Air fuel ratio gauge and setup with an O2 sensor bung welded into you exhaust. They make an O2 setup that runs off blue tooth... and talks to your phone....although I don't know how reliable it is. No one would know you have it.... if you want that stock look. I have a wired one in my car... and it really helps to get the tuning dialed in when you start tweaking the MPS. Also... timing can be another issue. I also run a 123+ distributor. On the hottest days here in the Midwest I see about 215.
Modern tools can really help. Something as simple as adding a couple of pounds of fuel pressure can add a touch more fuel and lower your temps. I found reading spark plugs hit and miss... as you could be lean and hot at cruise and by the time you got back to the garage things look good. The AFR takes some getting used to as it swings around lean to rich... but the goal is to get mix right when your engine is under load. I've dialed mine a little more rich... you sacrifice some fuel MPG... but it keeps the temps down. |
Ron914 Ron's 914 Mar 17 2026, 01:42 PM
930cabman My 2056 build is going on 4 years, basically stock... Mar 17 2026, 01:50 PM
burton73 Ron, Happy that you completed your smog. I just go... Mar 17 2026, 02:30 PM
Ron914
Ron, Happy that you completed your smog. I just g... Mar 17 2026, 03:08 PM
Ron914 @930cabman I too have a new 2056 motor and have b... Mar 17 2026, 02:56 PM
Superhawk996
Here is a mystery piece of tin that came in a bo... Mar 17 2026, 03:18 PM
Superhawk996 Regarding the calibration of your gage. That does... Mar 17 2026, 03:23 PM
Ron914
Regarding the calibration of your gage. That doe... Mar 17 2026, 04:04 PM
Superhawk996
Based on your post yesterday it sounds like I do... Mar 17 2026, 07:14 PM
Montreal914 Separate topic, but do you have a head temperature... Mar 17 2026, 04:43 PM
mgphoto I’ve had temps get really crazy hot trying a hig... Mar 17 2026, 08:42 PM
infraredcalvin I have one of these, but have never used it so, if... Mar 17 2026, 10:20 PM
fiacra
…. As for oil, ugh, plenty of opinions on that... Mar 18 2026, 08:53 AM
Ron914
…. As for oil, ugh, plenty of opinions on tha... Mar 18 2026, 10:50 AM
fiacra :headbang: Right...I forgot you had a 49 state ... Mar 18 2026, 11:18 AM
emerygt350 Can you check to see if that tin is missing? I ca... Mar 18 2026, 05:59 AM
emerygt350 I wouldn't be afraid of trying 40 weight or le... Mar 18 2026, 11:22 AM
infraredcalvin
I wouldn't be afraid of trying 40 weight or l... Mar 18 2026, 12:44 PM
emerygt350
[quote name='emerygt350' post='3249720' date='Mar... Mar 18 2026, 02:43 PM
sburns1967 In the first picture I do not see the thermostat c... Mar 18 2026, 01:43 PM
Ron914 Well I finally was able to get my AFR gauge instal... May 29 2026, 02:10 PM
FlacaProductions where is your sensor for the CHT gauge?
Under #3 p... May 29 2026, 02:47 PM
FlacaProductions Dakota Digital instructions to get from C to F dis... May 29 2026, 02:51 PM
emerygt350 Did you say your oil temp gauge jumps a quarter wa... May 29 2026, 05:12 PM
Ron914
Did you say your oil temp gauge jumps a quarter w... May 29 2026, 05:59 PM
emerygt350 Definitely a problem with the line or the gauge or... May 29 2026, 06:49 PM
Ron914
Definitely a problem with the line or the gauge o... May 29 2026, 08:19 PM
Ishley Pull the spark plugs and post a picture. Number ea... May 29 2026, 07:20 PM
Ron914
Pull the spark plugs and post a picture. Number e... May 29 2026, 08:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th May 2026 - 09:24 PM |
