| Ron914 |
Mar 17 2026, 01:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 19-April 22 From: Huntington Beach,Ca Member No.: 26,487 Region Association: Southern California
Hello all,
It's been about 4 months since I passed my smog test and thought I would be on the way to finally be able to drive my 4 year project . Well I have been enjoying driving it but only for short trips around town because I feel it has a high oil temperature problem . This is after a short drive around town of 30 minutes . A 45 minute drive will bring the needle on the gauge right to the red zone ,which looking at Phil's calibration photo would indicate about 250F , I don't continue to drive once I get to 250F and pull over and let its cool . Not exactly sure why or if it really is high ( I don't want to damage my new motor ) but I was given a few things to check by the members hers @Superhawk996 , @emerygt350 . First I checked my oil Temperature sensor to verify type and operation. It is a VDO 200 C sensor . I have the later oil gauge . I removed the sensor and placed it in 212F boiling water and it seems within the correct range on the console gauge . I am using a Efeng turkey fryer thermometer to check against the gauge in console . The thermometer is accurate . The gauge ( apex seems close to the same reading There was a discussion the other day on this subject with the question of whether missing a cooling tin on bottom of engine could cause the overheating problem @930cabman . I have the same issue as I have the tin that the shift rod passes through removed because it the shit rod comes into contact with the tin installed and it shifts better with it removed . Wondering if I should work on getting it reinstalled to help my cooling ? I have also worked on the cooling flaps /thermostat but will start a new post for those questions . I saw a comment about the type of oil . It sounds like Synthetic oil might be a better choice for air cooled oil . I currently have no oil in my motor and was wondering if Mobil Syn oil would be better than putting back in the Valvoline VR1 20-50W ? |
| mgphoto |
Mar 17 2026, 08:42 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,479 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I’ve had temps get really crazy hot trying a high advance with distributor vacuum. Took only minutes for oil temps to get out of hand.
Ron914 Ron's 914 Mar 17 2026, 01:42 PM
930cabman My 2056 build is going on 4 years, basically stock... Mar 17 2026, 01:50 PM
burton73 Ron, Happy that you completed your smog. I just go... Mar 17 2026, 02:30 PM
Ron914
Ron, Happy that you completed your smog. I just g... Mar 17 2026, 03:08 PM
Ron914 @930cabman I too have a new 2056 motor and have b... Mar 17 2026, 02:56 PM
Superhawk996
Here is a mystery piece of tin that came in a bo... Mar 17 2026, 03:18 PM
Superhawk996 Regarding the calibration of your gage. That does... Mar 17 2026, 03:23 PM
Ron914
Regarding the calibration of your gage. That doe... Mar 17 2026, 04:04 PM
Superhawk996
Based on your post yesterday it sounds like I do... Mar 17 2026, 07:14 PM
Ishley At some point you might want to look into an Air f... Mar 17 2026, 04:37 PM
Montreal914 Separate topic, but do you have a head temperature... Mar 17 2026, 04:43 PM
infraredcalvin I have one of these, but have never used it so, if... Mar 17 2026, 10:20 PM
fiacra
…. As for oil, ugh, plenty of opinions on that... Mar 18 2026, 08:53 AM
Ron914
…. As for oil, ugh, plenty of opinions on tha... Mar 18 2026, 10:50 AM
fiacra :headbang: Right...I forgot you had a 49 state ... Mar 18 2026, 11:18 AM
emerygt350 Can you check to see if that tin is missing? I ca... Mar 18 2026, 05:59 AM
emerygt350 I wouldn't be afraid of trying 40 weight or le... Mar 18 2026, 11:22 AM
infraredcalvin
I wouldn't be afraid of trying 40 weight or l... Mar 18 2026, 12:44 PM
emerygt350
[quote name='emerygt350' post='3249720' date='Mar... Mar 18 2026, 02:43 PM
sburns1967 In the first picture I do not see the thermostat c... Mar 18 2026, 01:43 PM
Ron914 Well I finally was able to get my AFR gauge instal... May 29 2026, 02:10 PM
FlacaProductions where is your sensor for the CHT gauge?
Under #3 p... May 29 2026, 02:47 PM
FlacaProductions Dakota Digital instructions to get from C to F dis... May 29 2026, 02:51 PM
emerygt350 Did you say your oil temp gauge jumps a quarter wa... May 29 2026, 05:12 PM
Ron914
Did you say your oil temp gauge jumps a quarter w... May 29 2026, 05:59 PM
emerygt350 Definitely a problem with the line or the gauge or... May 29 2026, 06:49 PM
Ron914
Definitely a problem with the line or the gauge o... May 29 2026, 08:19 PM
Ishley Pull the spark plugs and post a picture. Number ea... May 29 2026, 07:20 PM
Ron914
Pull the spark plugs and post a picture. Number e... May 29 2026, 08:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th May 2026 - 09:24 PM |
