| DRPHIL914 |
Mar 23 2026, 11:42 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,901 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
I think this has been getting slowly worse but I dont really run the car for a long drives around here and its been cold too, but yesterday during a longer drive to a PCA event, on my way back having a lot of stop and go traffic after the motor had warmed up and reached full operational temperatures, my idle was dropping below normal , about 500-600, and after stopping for gas and sitting for about 10 minutes idle was normal (1000rpm)
Motor is 2056 with d-jet, with ignition 123 distributor. fuel pressure is perfect, timing etc all good. all sensors were put in new when this motor was built 3-4 years ago. and i have always left the idle about 1100-1200 due to the fact that when it was fully hot it would come tdownt o 850-900 but never wanted to stall. My thought is that the CHT is acting up and the resistance must be too high hot and now is sending a signal making it just like normal d-jet would get heat sink if a hot motor sat for a short time then wouldnt start. - is that a lean or rich condition that happens i cant remember but looking for your ideas thoughts here. Phil |
| JeffBowlsby |
Mar 23 2026, 03:58 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,218 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Here is another thought.
Maybe the 'below normal 500-600' is actually normal - what the air bleed screw is actually calibrated to. When idle later increased to 1000, it was really reacting to a free air leak. If this is true, then you might look for a small air leak allowing free air in, somewhere in the intake system. Suggest using a smoke pencil to explore. |
DRPHIL914 D-jet masters question/help needed Mar 23 2026, 11:42 AM
914Sixer I would check fuel pump first. Heat is a killer f... Mar 23 2026, 12:13 PM
DRPHIL914 it’s a 75, fuel pump up front, it’s maybe only... Mar 23 2026, 12:48 PM
DRPHIL914 my other thought on the cht would be to pull it an... Mar 23 2026, 01:02 PM
emerygt350 Another possibility is that it is not running corr... Mar 23 2026, 01:27 PM
emerygt350 do you have an AFR gauge in it? Mar 23 2026, 01:29 PM
DRPHIL914
Maybe the 'below ... Mar 23 2026, 04:24 PM
DRPHIL914
Another possibility is that it is not running cor... Mar 23 2026, 04:15 PM
iankarr Forgive me if thesse suggestions sound basic...the... Mar 23 2026, 04:49 PM
emerygt350 You may want to try a cheapo Amazon o2. Air coole... Mar 23 2026, 05:29 PM
MDTerp My vote is for CHT sensor. I had a similar runnin... Mar 23 2026, 06:25 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd March 2026 - 07:37 PM |
