| DennisV |
Mar 25 2026, 07:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
If things go well next week, I might be able to take a run at installing the engine in our 914-6.
What should I do to prep for the marriage and / or a sequence of events should I follow to be most efficient? I’ve reviewed the Removing and Installing Engine section in the factory workshop manual. Any advice in addition, or contrary, to those steps? CURRENTLY * Engine is on a test stand * Transmission is on the floor * Chassis is on its wheels on a 4 post lift * Drive shafts are attached to the stub axle on the car * Wiring harness is on engine * Engine bay is pretty bare. No oil hoses, fuel hoses, fuel pump, engine wiring harness.
ASSUMPTIONS Before Engine In Car * Mate transmission to engine * Remove air cleaner * Oil hoses routed in engine bay * Fuel lines installed * Fuel hoses routed in engine bay * Fuel pump mounted * Heat exchangers on engine (ideally, but…) * Engine bay rubber seals After Engine In Car * Drive shafts attached * Shift rod * Muffler * Hot air ducts, flaps * Air cleaner QUESTIONS * Will the ramps or cross-beams of the lift cause clearance or height issues? Below is a shot of the lift. * Will it be a problem to install the heat exchangers after the engine is in the car? They won’t clear to supports on the test stand. * Should I install the oil and fuel hoses in the engine bay first? * If I use the parts catalog listed length on hoses, will I be OK? Or will I wish I hadn't cut the hoses to length until the engine is in? Thank you. ![]() |
VaccaRabite Since your car is on a lift, put the engine and tr... Mar 25 2026, 08:54 AM
DennisV
Since your car is on a lift, put the engine and t... Mar 25 2026, 09:08 AM
mlindner What six are you installing, or better yet what ar... Mar 25 2026, 09:26 AM
DennisV
What six are you installing, or better yet what a... Mar 25 2026, 09:32 AM
Tom1394racing I did this recently and waited to install the CV/A... Mar 25 2026, 10:01 AM
DennisV
I did the recently and waited to install the CV/A... Mar 25 2026, 12:25 PM
brant Did you drop the engine using the same lift?
I’... Mar 25 2026, 01:44 PM
DennisV
Iâ€... Mar 25 2026, 01:49 PM
SKL1 Looking at your lift, which is very similiar to mi... Mar 25 2026, 02:06 PM
DennisV
Looking at your lift, which is very similiar to m... Jun 16 2026, 10:11 AM
rgalla9146 Denis can you move the car rearward so the crossba... Mar 25 2026, 02:13 PM
mskala I have done the 4-post lift remove-install several... Mar 25 2026, 04:01 PM
930cabman I have been using a wood framed "table" ... Mar 25 2026, 05:11 PM
DennisV
I have been using a wood framed "table... Mar 26 2026, 07:15 AM
mskala Yes, heat exchangers/muffler can go on after insta... Mar 26 2026, 07:40 AM
Cairo94507 We used one of the Harbor Freight lift tables and ... Mar 26 2026, 09:36 AM
mepstein I think we have a total of about 7 HF lift tables.... Mar 26 2026, 09:49 AM
930cabman A work table is a great asset, one that lifts is e... Mar 26 2026, 10:45 AM
Cairo94507 We installed my '95 3.6, complete in non-vario... Jun 16 2026, 10:20 AM
morehills I removed my engine using a harbor freight table a... Jun 16 2026, 11:34 AM
930cabman
I removed my engine using a harbor freight table ... Jun 16 2026, 12:30 PM
DennisV The engine and transaxle are installed. Thanks for... Aug 23 2026, 11:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd August 2026 - 02:43 PM |
