> Engine Install Tips, 914-6 Order of Operations
DennisV
post Mar 25 2026, 07:47 AM
If things go well next week, I might be able to take a run at installing the engine in our 914-6.
What should I do to prep for the marriage and / or a sequence of events should I follow to be most efficient? I’ve reviewed the Removing and Installing Engine section in the factory workshop manual. Any advice in addition, or contrary, to those steps?
CURRENTLY
* Engine is on a test stand
* Transmission is on the floor
* Chassis is on its wheels on a 4 post lift
* Drive shafts are attached to the stub axle on the car
* Wiring harness is on engine
* Engine bay is pretty bare. No oil hoses, fuel hoses, fuel pump, engine wiring harness.
ASSUMPTIONS
Before Engine In Car
* Mate transmission to engine
* Remove air cleaner
* Oil hoses routed in engine bay
* Fuel lines installed
* Fuel hoses routed in engine bay
* Fuel pump mounted
* Heat exchangers on engine (ideally, but…)
* Engine bay rubber seals
After Engine In Car
* Drive shafts attached
* Shift rod
* Muffler
* Hot air ducts, flaps
* Air cleaner
QUESTIONS
* Will the ramps or cross-beams of the lift cause clearance or height issues? Below is a shot of the lift.
* Will it be a problem to install the heat exchangers after the engine is in the car? They won’t clear to supports on the test stand.
* Should I install the oil and fuel hoses in the engine bay first?
* If I use the parts catalog listed length on hoses, will I be OK? Or will I wish I hadn't cut the hoses to length until the engine is in?
Thank you.
VaccaRabite
post Mar 25 2026, 08:54 AM
En Garde!
Since your car is on a lift, put the engine and transmission on a motorcycle/transmission jack and lower the car on to the engine, using the transmission jack to do minute movements. The cross bar may interfere at the back of the 4 post lift. Or it may not. Hard to say given that photo.
Zach
DennisV
post Mar 25 2026, 09:08 AM
QUOTE(VaccaRabite @ Mar 25 2026, 07:54 AM) *
Hi Zach,
I have the Wilding Engineering 911 engine cradle adapter for a floor jack. Do floor jacks not normally raise high enough? Thus the need for a transmission jack?
I have some room to roll the car forward on the ramps, if the rear cross bar is the main concern. I wasn't sure about the minimum clearance needed between the ramps. I will also be limited to how much I can lower the lift, based on the floor jack. Maybe that's a non issue if the floor jack can lift high enough.
DennisV   Engine Install Tips   Mar 25 2026, 07:47 AM
VaccaRabite   Since your car is on a lift, put the engine and tr...   Mar 25 2026, 08:54 AM
DennisV   Since your car is on a lift, put the engine and t...   Mar 25 2026, 09:08 AM
mlindner   What six are you installing, or better yet what ar...   Mar 25 2026, 09:26 AM
DennisV   What six are you installing, or better yet what a...   Mar 25 2026, 09:32 AM
Tom1394racing   I did this recently and waited to install the CV/A...   Mar 25 2026, 10:01 AM
DennisV   I did the recently and waited to install the CV/A...   Mar 25 2026, 12:25 PM
brant   Did you drop the engine using the same lift? I’...   Mar 25 2026, 01:44 PM
DennisV   Did you drop the engine using the same lift? Iâ€...   Mar 25 2026, 01:49 PM
SKL1   Looking at your lift, which is very similiar to mi...   Mar 25 2026, 02:06 PM
DennisV   Looking at your lift, which is very similiar to m...   Jun 16 2026, 10:11 AM
rgalla9146   Denis can you move the car rearward so the crossba...   Mar 25 2026, 02:13 PM
mskala   I have done the 4-post lift remove-install several...   Mar 25 2026, 04:01 PM
930cabman   I have been using a wood framed "table" ...   Mar 25 2026, 05:11 PM
DennisV   I have been using a wood framed "table...   Mar 26 2026, 07:15 AM
mskala   Yes, heat exchangers/muffler can go on after insta...   Mar 26 2026, 07:40 AM
Cairo94507   We used one of the Harbor Freight lift tables and ...   Mar 26 2026, 09:36 AM
mepstein   I think we have a total of about 7 HF lift tables....   Mar 26 2026, 09:49 AM
930cabman   A work table is a great asset, one that lifts is e...   Mar 26 2026, 10:45 AM
Cairo94507   We installed my '95 3.6, complete in non-vario...   Jun 16 2026, 10:20 AM
morehills   I removed my engine using a harbor freight table a...   Jun 16 2026, 11:34 AM
930cabman   I removed my engine using a harbor freight table ...   Jun 16 2026, 12:30 PM
DennisV   The engine and transaxle are installed. Thanks for...   Aug 23 2026, 11:27 AM
7 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
2 Members: sbsix, Ninja
- Lo-Fi Version Time is now: 23rd August 2026 - 02:44 PM
