| DennisV |
Mar 25 2026, 07:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
If things go well next week, I might be able to take a run at installing the engine in our 914-6.
What should I do to prep for the marriage and / or a sequence of events should I follow to be most efficient? I’ve reviewed the Removing and Installing Engine section in the factory workshop manual. Any advice in addition, or contrary, to those steps? CURRENTLY * Engine is on a test stand * Transmission is on the floor * Chassis is on its wheels on a 4 post lift * Drive shafts are attached to the stub axle on the car * Wiring harness is on engine * Engine bay is pretty bare. No oil hoses, fuel hoses, fuel pump, engine wiring harness.
ASSUMPTIONS Before Engine In Car * Mate transmission to engine * Remove air cleaner * Oil hoses routed in engine bay * Fuel lines installed * Fuel hoses routed in engine bay * Fuel pump mounted * Heat exchangers on engine (ideally, but…) * Engine bay rubber seals After Engine In Car * Drive shafts attached * Shift rod * Muffler * Hot air ducts, flaps * Air cleaner QUESTIONS * Will the ramps or cross-beams of the lift cause clearance or height issues? Below is a shot of the lift. * Will it be a problem to install the heat exchangers after the engine is in the car? They won’t clear to supports on the test stand. * Should I install the oil and fuel hoses in the engine bay first? * If I use the parts catalog listed length on hoses, will I be OK? Or will I wish I hadn't cut the hoses to length until the engine is in? Thank you. ![]() |
| Cairo94507 |
Mar 26 2026, 09:36 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,744 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
We used one of the Harbor Freight lift tables and that really made it go smoothly. We installed engine and trans assembled. Easy to install transaxle when the engine is on the lift table. We did not have the heat exchangers on or the axles installed when we put the engine in. We did have to rock the engine to clear the suspension ear on the right if I recall correctly. But with the table it was an easy install. I still have my factory (original) engine mount and we used a long punch to line up the mount and then the bolt dropped right in place. After that was in we checked everything in the engine compartment for any conflicts and then installed the transaxle bolts. All in, took about 1/2 hour to get the engine bolted into the chassis. Good luck and enjoy the process. (IMG:style_emoticons/default/beerchug.gif)
DennisV Engine Install Tips Mar 25 2026, 07:47 AM
VaccaRabite Since your car is on a lift, put the engine and tr... Mar 25 2026, 08:54 AM
DennisV
Since your car is on a lift, put the engine and t... Mar 25 2026, 09:08 AM
mlindner What six are you installing, or better yet what ar... Mar 25 2026, 09:26 AM
DennisV
What six are you installing, or better yet what a... Mar 25 2026, 09:32 AM
Tom1394racing I did this recently and waited to install the CV/A... Mar 25 2026, 10:01 AM
DennisV
I did the recently and waited to install the CV/A... Mar 25 2026, 12:25 PM
brant Did you drop the engine using the same lift?
I’... Mar 25 2026, 01:44 PM
DennisV
Iâ€... Mar 25 2026, 01:49 PM
SKL1 Looking at your lift, which is very similiar to mi... Mar 25 2026, 02:06 PM
DennisV
Looking at your lift, which is very similiar to m... Jun 16 2026, 10:11 AM
rgalla9146 Denis can you move the car rearward so the crossba... Mar 25 2026, 02:13 PM
mskala I have done the 4-post lift remove-install several... Mar 25 2026, 04:01 PM
930cabman I have been using a wood framed "table" ... Mar 25 2026, 05:11 PM
DennisV
I have been using a wood framed "table... Mar 26 2026, 07:15 AM
mskala Yes, heat exchangers/muffler can go on after insta... Mar 26 2026, 07:40 AM
mepstein I think we have a total of about 7 HF lift tables.... Mar 26 2026, 09:49 AM
930cabman A work table is a great asset, one that lifts is e... Mar 26 2026, 10:45 AM
Cairo94507 We installed my '95 3.6, complete in non-vario... Jun 16 2026, 10:20 AM
morehills I removed my engine using a harbor freight table a... Jun 16 2026, 11:34 AM
930cabman
I removed my engine using a harbor freight table ... Jun 16 2026, 12:30 PM
DennisV The engine and transaxle are installed. Thanks for... Aug 23 2026, 11:27 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd August 2026 - 02:45 PM |
