| Root_Werks |
Mar 26 2026, 12:30 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,925 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Bought my current 914 6 years ago and the horn never worked. Finally got around to figuring out why yesterday.
Long story short: Nothing hacked (thank goodness!), still uses the factory relay. Steering column was converted to 924 or MK1 giving me intermittent wipers, accessory position etc. PO simply never took the wire from the horn button and plugged it to the relay. Problem solved, except, my horn sounds like a dying Goose, it's terrible. Thought about the Hella Supertone red horns, found an older thread where folks seem to like them and they bolt right up. http://www.914world.com/bbs2/index.php?showtopic=309534 Any other bolt-in options people like? I have a single horn, but could install a dual system. -Dan |
| porschetub |
Mar 26 2026, 03:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,054 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Bought my current 914 6 years ago and the horn never worked. Finally got around to figuring out why yesterday. Long story short: Nothing hacked (thank goodness!), still uses the factory relay. Steering column was converted to 924 or MK1 giving me intermittent wipers, accessory position etc. PO simply never took the wire from the horn button and plugged it to the relay. Problem solved, except, my horn sounds like a dying Goose, it's terrible. Thought about the Hella Supertone red horns, found an older thread where folks seem to like them and they bolt right up. http://www.914world.com/bbs2/index.php?showtopic=309534 Any other bolt-in options people like? I have a single horn, but could install a dual system. -Dan My roller didn't come with horns so because I had them I used mk3 VW Golf ones ,free,loud compact and bolted straight on ,the other good thing is they use waterproof 2 pin plugs which I cut of the VW horn loom, they were easy to adapt. Cheers. |
Root_Werks Horn options Mar 26 2026, 12:30 PM
Chad911sc I bought a set of those Hella super tones for my 6... Mar 26 2026, 12:48 PM
914werke In early bumpered cars the depth behind the bumper... Mar 26 2026, 12:50 PM
Root_Werks
In early bumpered cars the depth behind the bumpe... Mar 26 2026, 01:35 PM
chmillman I was able to fit a pair of HELLA Twin Tone trumpe... Mar 26 2026, 01:50 PM
friethmiller Dan,
For both of my 914s I've purchased orig... Mar 26 2026, 02:10 PM
friethmiller Deleted dup post Mar 26 2026, 02:12 PM
bkrantz I went with Hellas. The sounds a little bit Euro ... Mar 26 2026, 08:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th March 2026 - 04:32 AM |
