| TRP |
Mar 28 2026, 05:21 PM
Member ![]() ![]() Group: Members Posts: 274 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
What is this metal tube? I assume its part of the EGR / emissions system for a 1.8 and it allows gasses / vapors to flow back into the intake system. On my 1975 1.8 I do not have this metal tube, my car has this replicated via a series of rubber hoses and plastic connectors. Im wondering if a previous owner lost ir and recreated this part with the hoses/plastic connectors?
My car is a 1975, but it is not a smog system car. Should my car have this tube? Thank you, Ted |
| wonkipop |
Mar 28 2026, 07:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,474 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
as per Jeff.
@TRP i have your L jet data filed away in my L Jet files. as i recall your car no longer had the emissions sticker on the fan casting to identify the engine and compliance. but it did have the 918 paint stamp on the engine tin. from my files. which means its a 49 state USEPA only certified. also that it originally was base model engine (not appearance group) as 918 stamped engines lacked the temp sensor in the sump plate and associated wiring running up behind the fan casting. the hose diagram is here. http://www.914world.com/bbs2/index.php?sho...7407&st=280 refer engine family 15 hose diagram. cars with an EGR were california only as jeff bowlsby notes. also had a CAT and the throttle body was a twin port TB. the EGR was activated by the vacuum port above the throttle plate in the TB and the EGR connected to the PCV hose via the metal plumbing piece you are asking about. you should not have any of that. also indicates your car was originally sold outside of california when delivered new. (IMG:style_emoticons/default/beerchug.gif) |
TRP What is this tube? Mar 28 2026, 05:21 PM
JeffBowlsby The tube is part of the 1.8L EGR system. The 74 a... Mar 28 2026, 06:28 PM
wonkipop
as per Jeff.
@[url=http://www.914world.com/bbs2... Mar 28 2026, 07:36 PM
TRP Thank you both, I figured the two of you would kno... Mar 28 2026, 08:02 PM
bkrantz Reminds me how complicated (and desperate) auto em... Mar 28 2026, 08:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th March 2026 - 01:23 AM |
