| nmkimosabe |
Mar 21 2026, 09:44 AM
Member ![]() ![]() Group: Members Posts: 99 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
After a thorough investigation, it appears that the injectors are not getting ground to fire properly on my 1974 1.8L. Maybe it's an air flow sensor issue but not sure. All the other wiring seems to be okay. I would appreciate any thoughts from the knowledgeable folks on this forum. Thank you.
| JeffBowlsby |
Mar 31 2026, 05:41 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,392 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
L-Jet is one of the early EFI systems, common in the mid-1970s to many cars, not that hard to understand, here are some references. I would encourage you to follow a methodical troubleshooting process to locate the problem. Test each component individually. Its not likely the ECU:
https://bowlsby.net/914/Classic/zTN_Man12.pdf Here are other references if you need the theory of operation: https://bowlsby.net/914/Classic/zTN_Man07.pdf https://bowlsby.net/914/Classic/zTN_Man08.pdf https://bowlsby.net/914/Classic/zTN_Man15.pdf |
| nmkimosabe |
Mar 31 2026, 06:44 PM
L-Jet is one of the early EFI systems, common in the mid-1970s to many cars, not that hard to understand, here are some references. I would encourage you to follow a methodical troubleshooting process to locate the problem. Test each component individually. Its not likely the ECU: https://bowlsby.net/914/Classic/zTN_Man12.pdf Here are other references if you need the theory of operation: https://bowlsby.net/914/Classic/zTN_Man07.pdf https://bowlsby.net/914/Classic/zTN_Man08.pdf https://bowlsby.net/914/Classic/zTN_Man15.pdf @JeffBowlsby Thanks for all the great info and I will put together a game plan but I am starting without a lot of knowledge which makes it more challenging. But with input like this and other members of the forum I will get there. Thank you. |
nmkimosabe L-Jet Injectors Aren't Getting Ground Mar 21 2026, 09:44 AM
JeffBowlsby Check the schematic for these circuits. LJet injec... Mar 21 2026, 09:58 AM
nmkimosabe
Check the schematic for these circuits. LJet inje... Mar 21 2026, 04:25 PM
nmkimosabe
Check the schematic for these circuits. LJet inj... Mar 22 2026, 10:42 AM
Superhawk996
I will order a new resistor pack as mine might be... Mar 22 2026, 11:16 AM
nmkimosabe
I will order a new resistor pack as mine might b... Mar 22 2026, 12:55 PM
fiacra Jeff is the expert here so I'd start with what... Mar 21 2026, 12:15 PM
nmkimosabe
Jeff is the expert here so I'd start with wha... Mar 21 2026, 04:19 PM
Superhawk996 Just beware - lots of mechanics are basically lear... Mar 22 2026, 01:24 PM
nmkimosabe
Just beware - lots of mechanics are basically lea... Mar 22 2026, 02:11 PM
nmkimosabe Here's an update on my 914 and unfortunately, ... Mar 31 2026, 05:07 PM
Superhawk996 . I had the car towed to my mechanic who spent 2 d... Mar 31 2026, 07:45 PM
nmkimosabe
. I had the car towed to my mechanic who spent 2 ... Apr 1 2026, 09:14 AM
Superhawk996
A) I believe it is getting spark, and fuel but j... Apr 1 2026, 12:11 PM
Rob-O I’m with Superhawk. Make a plan and methodicall... Apr 1 2026, 11:39 AM
nmkimosabe
I’m with Superhawk. Make a plan and methodical... Apr 1 2026, 12:13 PM
Superhawk996
Yes I can use a voltmeter and I have a list of t... Apr 1 2026, 12:48 PM
StarBear Also check the o-ring on the oil filler cap. A fai... Apr 1 2026, 12:28 PM
nmkimosabe
Also check the o-ring on the oil filler cap. A fa... Apr 1 2026, 02:42 PM
Maltese Falcon Check your main grounds around the engine bay/ and... Apr 1 2026, 12:31 PM
nmkimosabe
Check your main grounds around the engine bay/ an... Apr 1 2026, 04:07 PM
nmkimosabe Well 2 weeks and learning a lot about L-jet inject... Apr 7 2026, 02:38 PM
TRP great job at debugging the issue! I have so m... Apr 7 2026, 03:00 PM
Rob-O The head sensor isn’t terribly difficult. Take ... Apr 8 2026, 04:16 AM
nmkimosabe
The head sensor isn’t terribly difficult. Take... Apr 8 2026, 08:24 AM
Rob-O For gaskets it depends. The injectors could be le... Apr 9 2026, 06:25 AM
Geezer914 If it's running like crap, it may be a vacuum ... Apr 9 2026, 09:12 AM
nmkimosabe Can someone please tell me if I should use a crush... Apr 11 2026, 02:22 PM
fiacra
Can someone please tell me if I should use a crus... Apr 11 2026, 04:03 PM
nmkimosabe
[quote name='nmkimosabe' post='3252868' date='Apr... Apr 11 2026, 07:35 PM
nmkimosabe
Can someone please tell me if I should use a cru... Apr 12 2026, 08:43 AM
fiacra @[url=http://www.914world.com/bbs2/index.php?showu... Apr 12 2026, 11:39 AM
nmkimosabe @fiacra
My part # appears to be 032.096.041 which... Apr 12 2026, 01:06 PM
fiacra
[b]@[url=http://www.914world.com/bbs2/index.php?s... Apr 12 2026, 03:06 PM
nmkimosabe
[b]@[url=http://www.914world.com/bbs2/index.php?... Apr 12 2026, 03:55 PM
Superhawk996 RE: L-Jet Injectors Aren't Getting Ground Apr 12 2026, 02:30 PM
Rob-O They’re available from Porsche again, I believe. Apr 12 2026, 03:36 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th November 2026 - 09:27 PM |
