> High idle problem, Hunting
Flyinlow
post Mar 31 2026, 05:39 PM
Flyinlow
Nearing the end of my restoration drove car today for first time in 30 years!! Start up is 1000 rpm a little high…. Then on its own goes to 3000 rpm then seems to settle to 2500 rpm.. when shifting rpm rises? I checked throttle cable for routing… all good and it did decel but not quickly as it seemed to be hunting any help much appreciated.TIA Dennis (IMG:style_emoticons/default/blink.gif)
mgphoto
post Mar 31 2026, 05:53 PM
"If there is a mistake it will find me"
Big air leak in the intake.
porschetub
post Mar 31 2026, 11:54 PM
QUOTE(mgphoto @ Apr 1 2026, 12:53 PM) *
Certainly sounds like it, quick test on the throttle cable ,when the engine is up to temp disconnect it and see what it does .
The vacuum leak is a telltale of loose /leaking air hose/s or many other reasons ,D-jet isn't happy with air leaks ,even a small leak will render the air screw to no non -op .
Go back and check everything ,cheers.
- Lo-Fi Version Time is now: 1st April 2026 - 03:02 AM
