| DC_neun_vierzehn |
Apr 3 2026, 08:02 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 642 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
I'm still a newbee on valve adjustments. I have a 73 2.0 (2056).
I've watched Ian's video a dozen or more times. His engine is on a stand the heads are vertical. My engine is in my car so my heads are horizontal. I'm trying to get a feel for how much drag my feeler gauge should have between the valve adjuster screw and the valve stem. Should the feeler gauge be able to drop through the gap without forcing it through the gap? Or should it be able to pass through the gap if pushed, but stay "stuck" in the gap without being pushed? Should there be any bend in the feller gauge to push it through? |
| Ninja |
Apr 3 2026, 12:58 PM
Member ![]() ![]() Group: Members Posts: 193 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
Art/science ?? About 50-50. It is an acquired 'touch'. You should not have force the correct gauge to slide thru. use a gauge .001 or .002 larger to check it isn't too loose. That one SHOULD be hard to side thru (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) Use 3 feeler gauges. -.001 under should be floppy loose. Correct should slide with light force. +.001 should be a FIGHT to get in. |
DC_neun_vierzehn Valve Adjustment Question(s) Apr 3 2026, 08:02 AM
Chad911sc It should be able to pass through the gap with min... Apr 3 2026, 08:10 AM
DC_neun_vierzehn
It should be able to pass through the gap with mi... Apr 3 2026, 11:45 AM
fiacra
I'm still a newbee on valve adjustments. I ha... Apr 3 2026, 12:04 PM
fixer34 Art/science ?? About 50-50. It is an acquired ... Apr 3 2026, 12:17 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd April 2026 - 03:29 PM |
