| LefthandRev |
Apr 3 2026, 04:48 PM
Member ![]() ![]() Group: Members Posts: 87 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
I got into my car a couple days ago, turned the key, and the compartment started to smoke. Looked to my right and a couple of wires were melting behind the passenger seat. They had shorted and I grabbed and pulled to stop any potential fire (after shutting off the ignition).
Fast forward a couple days when I'm diagnosing things. I pull the passenger side seat out. Found the wires. Started tracing them, looking to see if there was something in the engine compartment, etc., found the probable cause for my woes - the coil was just laying flat on the engine shroud under the passenger side carb. One of the mounting screws had worked itself out and the whole thing was just sitting on the engine, so I'm sure it shorted whatever these wires are. I'll dig into diagrams soon, but hopefully someone can save me a little time if they recognize them. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1775256488.1.png) (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-25787-1775256489.2.png) |
| JeffBowlsby |
Apr 3 2026, 09:11 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,228 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
If those two big fat yella wires are not connected together yet, it’s advisable to do that to avoid lotsa heartburn.
https://bowlsby.net/914/Classic/zTN_SeatbeltRelayBypass.jpg |
| Flyinlow |
Apr 4 2026, 08:59 AM
Flyinlow ![]() ![]() Group: Members Posts: 140 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
If those two big fat yella wires are not connected together yet, it’s advisable to do that to avoid lotsa heartburn. https://bowlsby.net/914/Classic/zTN_SeatbeltRelayBypass.jpg Question…when those yellow wires are connected does that render the rest of them inoperable? (IMG:style_emoticons/default/blink.gif) |
| porschetub |
Apr 4 2026, 03:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,074 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
If those two big fat yella wires are not connected together yet, it’s advisable to do that to avoid lotsa heartburn. https://bowlsby.net/914/Classic/zTN_SeatbeltRelayBypass.jpg Question…when those yellow wires are connected does that render the rest of them inoperable? (IMG:style_emoticons/default/blink.gif) I believe so , my roller came less the relays , I cut the fat yellow cables going into the relay block and used a large Duraseal connector ,simple crimp and heat to provide a sealed joint . Cheers. |
LefthandRev Wiring Woes - Shorted Out Mystery Wires. Apr 3 2026, 04:48 PM
bkrantz Part of the evil seat belt starter interlock syste... Apr 3 2026, 07:49 PM
dtmehall if the picture is accurate :agree:
removed it de... Apr 3 2026, 07:59 PM
porschetub
[quote name='JeffBowlsby' post='3251902' date='Ap... Apr 4 2026, 03:22 PM
ejm Looks like the power wire for the interior light. Apr 4 2026, 05:32 AM
JeffBowlsby It takes circumvents the seatbelt interlock relay,... Apr 4 2026, 03:21 PM
LefthandRev Well, crap - I wrote something up, but it didn... Apr 6 2026, 09:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 8th April 2026 - 04:59 AM |
