> Windshield Washer Electric Pump, Makes noise, but no squirt
DennisV
post Jan 10 2026, 08:35 PM
Testing the windshield washer in our 1970 914-6. When I pull the wiper / washer lever I can hear a slight thud or click and then the wipers cycle. I have confirmed the noise is the electric pump as I can feel it move slightly if I put my hand on it while someone else pulls the lever. Does that mean the pump is good, or does a good working pump make a different noise?
I've been through many threads about the squirters not working, but haven't found much discussion about the electric pump itself.
Thanks.
DennisV
post Apr 6 2026, 02:00 PM
A related tip on this topic. The hoses are secured to the pump with very thin wire (0.80 mm diameter) twisted around them. It broke when I removed it.
The closest I could find is 24 gauge floral wire at Menards. It is 0.60 mm diameter and green, but worked quite well and is out of view.
BillC
post Apr 6 2026, 04:06 PM
QUOTE(DennisV @ Apr 6 2026, 04:00 PM) *
That looks like safety wire. Readily available at any speed shop, as well as Summit Racing, Jegs, Amazon, etc. The twisting is done with a special pair of pliers that has a pull-twister, specifically for safety wire.
DennisV   Windshield Washer Electric Pump   Jan 10 2026, 08:35 PM
Superhawk996   Should be a constant hum / whirring Clunk / thun...   Jan 10 2026, 08:53 PM
porschetub   Testing the windshield washer in our 1970 914-6. ...   Jan 10 2026, 08:54 PM
johnhora   DennisV....The pumps get gummed up inside and make...   Jan 10 2026, 09:06 PM
DennisV   DennisV....The pumps get gummed up inside and mak...   Jan 19 2026, 02:19 PM
rgalla9146   Original pumps are dated approximate to (but befor...   Jan 11 2026, 07:04 AM
914Sixer   Clean the whole system if you have to take pump ap...   Jan 11 2026, 07:30 AM
Cairo94507   Hey Dennis, great job on the washer motor video. ...   Jan 20 2026, 08:01 AM
johnhora   :agree: Nice informative video Dennis..   Jan 20 2026, 03:51 PM
NARP74   Nice video. The grease you used will wind up in t...   Jan 20 2026, 05:04 PM
Steve   Enlarged prostate? Jk.. I had to prime mine to g...   Jan 20 2026, 08:49 PM
DennisV   A related tip on this topic. The hoses are secured...   Apr 6 2026, 02:00 PM
BillC   A related tip on this topic. The hoses are secure...   Apr 6 2026, 04:06 PM
914Sixer   Wire is NOT stock.   Apr 6 2026, 06:49 PM
rgalla9146   Wire is NOT stock. :agree: fresh hose ...   Apr 6 2026, 07:38 PM
DennisV   Wire is NOT stock. :o Thank you for pointing t...   Apr 7 2026, 06:48 AM
aturboman   As mentioned the original pumps have date markings...   Apr 9 2026, 11:09 AM
DennisV   As mentioned the original pumps have date marking...   May 26 2026, 05:04 AM
Superhawk996   Bench test rather than playing with it in car. Ai...   May 26 2026, 11:05 AM
Cairo94507   I just spent the afternoon trying to sort my washe...   Jul 7 2026, 04:08 PM
Cairo94507   Look what I found using the search function:   Jul 8 2026, 07:17 AM
Cairo94507   Jesus! This windshield washer system is makin...   Jul 11 2026, 11:28 AM
DennisV   Jesus! This windshield washer system is maki...   Jul 11 2026, 11:52 AM
Cairo94507   Dennis - I was able to use a couple of putty knife...   Jul 11 2026, 05:07 PM
rgalla9146   The check valves at the squirters get stuck and wi...   Jul 12 2026, 04:58 AM
wonkipop   The check valves at the squirters get stuck and w...   Aug 21 2026, 06:52 PM
Cairo94507   Ohhhh, that is interesting. Stuck check valves ma...   Jul 12 2026, 07:38 AM
DennisV   Ohhhh, that is interesting. Stuck check valves m...   Aug 21 2026, 10:11 AM
Cairo94507   Hi Dennis, What did you do to free up that valve i...   Aug 21 2026, 02:47 PM
DennisV   Hi Dennis, What did you do to free up that valve ...   Aug 21 2026, 02:52 PM
jim_hoyland   Had the same issue. I removed the vent cap and dri...   Aug 21 2026, 07:20 PM
wonkipop   looking at parts diagram above and made me think. ...   Aug 21 2026, 08:07 PM
- Lo-Fi Version Time is now: 22nd October 2026 - 01:45 PM
