| DennisV |
Jan 10 2026, 08:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,040 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Testing the windshield washer in our 1970 914-6. When I pull the wiper / washer lever I can hear a slight thud or click and then the wipers cycle. I have confirmed the noise is the electric pump as I can feel it move slightly if I put my hand on it while someone else pulls the lever. Does that mean the pump is good, or does a good working pump make a different noise?
I've been through many threads about the squirters not working, but haven't found much discussion about the electric pump itself. Thanks. |
| 914Sixer |
Apr 6 2026, 06:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,599 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Wire is NOT stock.
| DennisV |
Apr 7 2026, 06:48 AM
DennisV Windshield Washer Electric Pump Jan 10 2026, 08:35 PM
Superhawk996 Should be a constant hum / whirring
Clunk / thun... Jan 10 2026, 08:53 PM
porschetub
Testing the windshield washer in our 1970 914-6. ... Jan 10 2026, 08:54 PM
johnhora DennisV....The pumps get gummed up inside and make... Jan 10 2026, 09:06 PM
DennisV
DennisV....The pumps get gummed up inside and mak... Jan 19 2026, 02:19 PM
rgalla9146 Original pumps are dated approximate to (but befor... Jan 11 2026, 07:04 AM
914Sixer Clean the whole system if you have to take pump ap... Jan 11 2026, 07:30 AM
Cairo94507 Hey Dennis, great job on the washer motor video. ... Jan 20 2026, 08:01 AM
johnhora :agree: Nice informative video Dennis.. Jan 20 2026, 03:51 PM
NARP74 Nice video. The grease you used will wind up in t... Jan 20 2026, 05:04 PM
Steve Enlarged prostate? Jk.. I had to prime mine to g... Jan 20 2026, 08:49 PM
DennisV A related tip on this topic. The hoses are secured... Apr 6 2026, 02:00 PM
BillC
A related tip on this topic. The hoses are secure... Apr 6 2026, 04:06 PM
rgalla9146
Wire is NOT stock.
:agree:
fresh hose ... Apr 6 2026, 07:38 PM
aturboman As mentioned the original pumps have date markings... Apr 9 2026, 11:09 AM
DennisV
As mentioned the original pumps have date marking... May 26 2026, 05:04 AM
Superhawk996 Bench test rather than playing with it in car. Ai... May 26 2026, 11:05 AM
Cairo94507 I just spent the afternoon trying to sort my washe... Jul 7 2026, 04:08 PM
Cairo94507 Look what I found using the search function:
Jul 8 2026, 07:17 AM
Cairo94507 Jesus! This windshield washer system is makin... Jul 11 2026, 11:28 AM
DennisV
Jesus! This windshield washer system is maki... Jul 11 2026, 11:52 AM
Cairo94507 Dennis - I was able to use a couple of putty knife... Jul 11 2026, 05:07 PM
rgalla9146 The check valves at the squirters get stuck and wi... Jul 12 2026, 04:58 AM
wonkipop
The check valves at the squirters get stuck and w... Aug 21 2026, 06:52 PM
Cairo94507 Ohhhh, that is interesting. Stuck check valves ma... Jul 12 2026, 07:38 AM
DennisV
Ohhhh, that is interesting. Stuck check valves m... Aug 21 2026, 10:11 AM
Cairo94507 Hi Dennis,
What did you do to free up that valve i... Aug 21 2026, 02:47 PM
DennisV
Hi Dennis,
What did you do to free up that valve ... Aug 21 2026, 02:52 PM
jim_hoyland Had the same issue. I removed the vent cap and dri... Aug 21 2026, 07:20 PM
wonkipop looking at parts diagram above and made me think.
... Aug 21 2026, 08:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd October 2026 - 01:46 PM |
