| chandler1969 |
Apr 7 2026, 07:03 AM
Member ![]() ![]() Group: Members Posts: 121 Joined: 2-January 06 From: Georgetown, Ky Member No.: 5,352 Region Association: None |
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO.
| DennisV |
Apr 7 2026, 07:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 897 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO. Went through this myself not long ago. You could try hitting them with a small propane or butane torch if you can control the flame. Otherwise I'd grab them with vice grips to break them free. Even if it's the threaded side for a secure grip. Replace the screws. Last resort cut them off with a Dremel. |
| chandler1969 |
Apr 7 2026, 07:57 AM
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO. Went through this myself not long ago. You could try hitting them with a small propane or butane torch if you can control the flame. Otherwise I'd grab them with vice grips to break them free. Even if it's the threaded side for a secure grip. Replace the screws. Last resort cut them off with a Dremel. Thanks, I was thinking the same but wanted some expert advise before proceeding! |
chandler1969 Rusted Screws Advice Apr 7 2026, 07:03 AM
Jamie
Need some advise on rusted screws that hold the h... Apr 7 2026, 07:24 AM
chandler1969
Need some advise on rusted screws that hold the ... Apr 7 2026, 07:56 AM
mepstein A bit of heat from an torch and then touch a piece... Apr 7 2026, 07:37 AM
chandler1969
A bit of heat from an torch and then touch a piec... Apr 7 2026, 07:57 AM
914werke Here you go!
http://www.914world.com/bbs2/ind... Apr 7 2026, 08:43 AM
914werke Whoops link didnt work ...Here you go!
HERE
... Apr 7 2026, 08:44 AM
chandler1969
Here you go!
[color=#3333FF][url=http://www.... Apr 7 2026, 09:06 AM
chandler1969
Here you go!
[color=#3333FF][url=http://www.... Apr 7 2026, 09:08 AM
914werke
Need some advise on rusted screws that hold the h... Apr 7 2026, 09:14 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th April 2026 - 10:09 PM |
