> Recommisioning a '73 Driver Project, making another 914 roadworthy again
Literati914
post Apr 8 2026, 03:13 PM
Couple months back I bought a Phoenix Red 1.7L '73 that I planned to do a "quick resto/refresh" on. The idea was to get it back on the road as a very descent driver, no rotisserie work or complete strip down for repaint. Mainly wanted to make it structurally and mechanically sound. I've been working on it and snapping a few pic as I go, so I thought I'd go ahead and post a thread about it here.
Literati914
post Apr 9 2026, 11:18 AM
QUOTE(Jamie @ Apr 9 2026, 11:58 AM) *
Those internal screens are so useless! I destroyed 2 trying to install, and a filter on the outside is a much better protection, and easily changed when needed without having to drain the tank. (IMG:style_emoticons/default/bootyshake.gif)
I hear ya, I'd probably skip it if it was a tank that had been used continually for some time up until now. But since the car has sat for several years and I'm hoping there's only minimal crud hiding in the tank - it feels like a safe addition. Of course I'll have a regular filter before the pump too.
Literati914   Recommisioning a '73 Driver Project   Apr 8 2026, 03:13 PM
Literati914   Basic Appearance: First of all, it obviously need...   Apr 8 2026, 03:33 PM
wonkipop   Basic Appearance: First of all, it obviously nee...   Apr 22 2026, 02:23 PM
Literati914   Obvious Issues: Leaning right rear wheel and a ri...   Apr 8 2026, 03:54 PM
930cabman   Obvious Issues: Leaning right rear wheel and a r...   Apr 8 2026, 06:11 PM
Literati914   Then it was on to the riveted license late that wa...   Apr 8 2026, 03:59 PM
Literati914   Repairs   Apr 8 2026, 04:06 PM
Literati914   Engine Compartment: The hell-hole is in great cond...   Apr 8 2026, 04:14 PM
Literati914   ..and the replacement tray   Apr 8 2026, 04:16 PM
Literati914   I also, weld/reinforced the engine lid brackets un...   Apr 8 2026, 04:18 PM
Literati914   There was a repair at the lower firewall area at t...   Apr 8 2026, 04:24 PM
Literati914   Then I turned my attention to the floors: I remove...   Apr 8 2026, 04:33 PM
Literati914   more examples -   Apr 8 2026, 04:35 PM
Literati914   Finally I added two coats of Chassis Saver rust pr...   Apr 8 2026, 04:38 PM
Literati914   I re-installed the cleaned up and re-sprayed trail...   Apr 8 2026, 04:46 PM
seanpaulmc   Good on you for bringing another one back! So ...   Apr 8 2026, 05:19 PM
Literati914   Good on you for bringing another one back! So...   Apr 8 2026, 05:42 PM
Literati914   New ear is great, how did you manage the "co...   Apr 8 2026, 07:30 PM
Literati914   Here's the other rocker, I did work on the rec...   Apr 8 2026, 07:34 PM
Literati914   The car was missing it's trunk torsion rods an...   Apr 8 2026, 07:38 PM
Literati914   I currently got the nose up to work on fuel tank e...   Apr 8 2026, 07:42 PM
dtmehall   it doesn't look like a creeper would work on t...   Apr 8 2026, 07:47 PM
Literati914   it doesn't look like a creeper would work on ...   Apr 8 2026, 08:29 PM
dtmehall   :( use lot's of voltaren!   Apr 8 2026, 08:34 PM
Literati914   I pulled the old original fuel lines and bent up s...   Apr 8 2026, 09:12 PM
Literati914   Installed   Apr 8 2026, 09:13 PM
slowrodent   This is clearly much more than a "quick refre...   Apr 9 2026, 07:22 AM
Literati914   The front areas of this car are pretty nice.. I cl...   Apr 9 2026, 09:41 AM
friethmiller   Nice work, @Literati914 . This thing will be bac...   Apr 9 2026, 09:54 AM
Literati914   I'd planned to do an internal cleaning of the ...   Apr 9 2026, 09:54 AM
Literati914   A new mesh screen is going back in too.   Apr 9 2026, 09:56 AM
Jamie   A new mesh screen is going back in too. Those in...   Apr 9 2026, 10:58 AM
Literati914   Those internal screens are so useless! I dest...   Apr 9 2026, 11:18 AM
Literati914   As mentioned earlier someone had altered the fuse ...   Apr 21 2026, 03:01 PM
Literati914   Grabbed a spare OEM fuse holder and reinstalled it...   Apr 21 2026, 03:02 PM
Literati914   The real problem was the unorganized nest of wirin...   Apr 21 2026, 03:05 PM
Literati914   There were many issues, particularly with the ligh...   Apr 21 2026, 03:09 PM
Literati914   Now we have this at both sides. Hopefully I can ge...   Apr 21 2026, 03:11 PM
Literati914   I tested the original speedo cable and it was not ...   Apr 21 2026, 03:17 PM
Literati914   Speedometer cable installed. Note in this pic, the...   Apr 21 2026, 03:20 PM
Literati914   Then I moved to the wiring for the brake warning s...   Apr 21 2026, 03:22 PM
Literati914   Got that repaired, and re-taped the whole area.   Apr 21 2026, 03:24 PM
Literati914   Next on the agenda - As I had mentioned the heat/d...   Apr 21 2026, 03:29 PM
bkrantz   Great work! I am curious how the suspension e...   Apr 21 2026, 07:15 PM
Literati914   Great work! I am curious how the suspension ...   Apr 21 2026, 10:31 PM
wonkipop   phoenix red. what a great color :beer2: . keep ...   Apr 22 2026, 04:12 AM
Literati914   Wiring reconnected and put back into place.   Apr 22 2026, 01:28 PM
Literati914   Slider unit and FSB light back in..   Apr 22 2026, 01:30 PM
Literati914   Great. Except after I went through removing the cu...   Apr 22 2026, 01:40 PM
Literati914   So then I got to do this (fun! :angry: )   Apr 22 2026, 01:41 PM
Artfrombama   Great restoration thread, thanks for documenting t...   Apr 22 2026, 02:46 PM
Literati914   .. yeah that steering wheel is interesting if it ...   Apr 23 2026, 10:35 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Apr 23 2026, 01:24 PM
Literati914   I managed to get the defrost unit replaced, cables...   Apr 24 2026, 08:47 AM
Literati914   Time to re-install the fuel tank… not so fast, b...   Apr 24 2026, 08:51 AM
Literati914   Tank back in.   Apr 24 2026, 08:52 AM
Literati914   The harness in the frunk was bothering me with all...   Apr 24 2026, 08:53 AM
Literati914   So I cleaned it up and re-taped it. Ps - note in ...   Apr 24 2026, 08:58 AM
Literati914   Both the areas by the headlight motors looked like...   Apr 24 2026, 05:44 PM
Literati914   So I cleaned these areas up and probably avoided a...   Apr 24 2026, 05:46 PM
Literati914   Other side :D   Apr 24 2026, 05:47 PM
Literati914   Moved to the back and cleaned up and installed the...   Apr 25 2026, 12:38 PM
Literati914   The right side   Apr 25 2026, 12:40 PM
Literati914   Wires going back to the trunk were in a sorry stat...   Apr 25 2026, 12:43 PM
Literati914   Cleaned up, re-taped.. and now reinstalled   Apr 25 2026, 12:44 PM
Literati914   Which leads me to tail lights. The right side tail...   Apr 27 2026, 07:31 PM
Literati914   The thin seals around the lenses were both deterio...   Apr 27 2026, 07:33 PM
Literati914   Jumped up to the front and cleaned up the suspensi...   Apr 27 2026, 07:41 PM
Literati914   The targa top on this car was in bad shape. The fi...   May 29 2026, 09:02 PM
Literati914   After sanding smooth and some filler, this pic is ...   May 29 2026, 09:04 PM
Literati914   I picked up a 1 gal. Herculiner roll-on kit, unuse...   May 29 2026, 09:10 PM
Literati914   The kit came with textured rollers and I did use s...   May 29 2026, 09:14 PM
Literati914   I had left over bed liner and decided to coat the ...   Jun 5 2026, 10:20 AM
Literati914   I roughed up the surface and applied it over the o...   Jun 5 2026, 10:26 AM
Literati914   I added hydraulic hood support struts to the front...   Jun 7 2026, 07:10 PM
Literati914   So much better imho, now that I’m not hearing th...   Jun 7 2026, 07:15 PM
HFC3   Great job!   Jun 8 2026, 06:51 PM
Literati914   Started reinstalling the interior. Seat belts are ...   Jun 10 2026, 02:29 PM
Literati914   The Backpad needed some love just to make it usabl...   Jun 10 2026, 02:34 PM
Literati914   Front side. The tabs on the reverse side are solid...   Jun 10 2026, 02:38 PM
Literati914   .. and solidly installed now :Qarl:   Jun 10 2026, 02:42 PM
Literati914   Been a while since I posted on this project.. but ...   Oct 11 2026, 07:01 PM
Literati914   I even had enough to get some inside both doors :...   Oct 11 2026, 07:04 PM
gereed75   I really love these kind of functional restoration...   Oct 12 2026, 04:59 AM
Literati914   I installed some thick automotive carpet pad/under...   Oct 24 2026, 03:44 PM
Literati914   Oh yea, I also installed the center seat belt latc...   Oct 24 2026, 04:06 PM
Literati914   I mean, this should work electrically, and they ce...   Oct 24 2026, 04:10 PM
Literati914   The front valance on this car was a mess - pretty ...   Nov 23 2026, 07:17 PM
Literati914   Forgot to get an after pic, but it came out nice a...   Nov 23 2026, 07:19 PM
Literati914   Been jumping all over the place on this car.. I go...   Nov 23 2026, 07:24 PM
Literati914   Engine de-tinned and before clean up   Nov 23 2026, 07:26 PM
Literati914   Cleaned up, going back together w/ a new oil coole...   Nov 23 2026, 07:28 PM
Literati914   Transmission got seals replaced, including the lit...   Nov 23 2026, 07:33 PM
Literati914   Then I jumped over and installed the fuel pump tha...   Nov 23 2026, 07:43 PM
Literati914   Kept feeling like there was something else I neede...   Nov 23 2026, 07:46 PM
Literati914   So I dug out as much old grease as possible, clean...   Nov 23 2026, 07:48 PM
worn   This is turning out to be a very desirable sports ...   Nov 24 2026, 07:01 PM
Root_Werks   Progress is looking good!   Nov 25 2026, 12:25 PM
- Lo-Fi Version Time is now: 25th November 2026 - 11:46 PM
