| ctc911ctc |
Apr 13 2026, 10:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
***Go to the end for the UPDATE***
Hi all you teeners My car's idle sticks at 2k if I turn it off and start it immediately it goes back to 950. Looking for a vendor to fix this - I of course rebuilt it when the engine was out. I am sure all was done correctly (IMG:style_emoticons/default/confused24.gif) I believe that the wrong springs may have been in the rebuild kit. Is there a vendor that rebuilds and calibrates these? Thank you Teeners! CTC911CTC |
| Superhawk996 |
Apr 13 2026, 11:10 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,944 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Wrong springs will not make a dizzy sticky and hold at a given rpm.
Check your sliding advance plate within the dizzy. Check your carb linkage |
| porschetub |
Apr 14 2026, 07:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,137 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Wrong springs will not make a dizzy sticky and hold at a given rpm. Check your sliding advance plate within the dizzy. Check your carb linkage (IMG:style_emoticons/default/agree.gif) it can only be the advance weights not returning ,wrong springs will only effect when and how the advance comes in, my Marelli was I bit gummed up so give it a good clean and fine ,these are very simple units and robust ,but I remember Clay mentioned they can hang up on the advance stops ,hopefully he will chime in as appears he knew their issues well ,cheers and good luck . |
ctc911ctc *Update* Distributor - 1970 914-6 all stock Apr 13 2026, 10:47 AM
DennisV
Hi all you teeners
My car's idle sticks at 2... Apr 13 2026, 11:45 AM
930cabman I might first watch the timing marks and see if th... Apr 13 2026, 12:44 PM
914Sixer Sparx Werks Apr 13 2026, 01:02 PM
fiacra Second vote for Bill at SparxWerks. He has done t... Apr 13 2026, 01:06 PM
gms By stock I assume you are talking about a Marelli ... Apr 17 2026, 07:35 AM
mskala I have almost 3 of these Marelli units. One was w... Apr 18 2026, 08:03 AM
sixnotfour :beer1: Apr 22 2026, 09:30 PM
ctc911ctc looks like someone has cornered the market for the... Jul 13 2026, 10:25 AM
ctc911ctc Soooooooooooo
I got this car running - and mechan... Jul 13 2026, 11:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th July 2026 - 07:25 PM |
