| 914rrr |
Apr 16 2026, 07:35 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 1-July 03 From: McMinnville, TN Member No.: 874 Region Association: South East States |
My 75 1.8 has a really nice but cut-down / modified 911 rear center reflector. I was fiddling with the taillights last weekend and may have disturbed the solenoid wiring for the rear trunk release. Now the button won't pop the rear trunk open.
Many years ago I had a similar set up and drilled a tiny hole in the reflector in order to insert a thin allen wrench to open the rear trunk in emergencies. Since the reflector is already cut and only useful to 914 owners, would drilling a small hole in my reflector decrease it's value? I'm contemplating removing the reflector and going back to the stock set up. Thoughts? |
| Jack Standz |
Apr 16 2026, 02:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 762 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Our '74 has the rear modified 911 reflector. A cable with a small handle was run into the engine compartment by the PO from the trunk latch.
It works and no hole in the center of the reflector. Yes, the hole will impact the value/$ But really, if you make this modification to your 914, the reflector looks better without the hole in it. And some even say the 914 looks better without the modified 911 reflector that doesn't belong on a (stock) 914. You do you, hole or not. |
914rrr Would drilling a small hole in a PORSCHE center reflector hurt it's value? Apr 16 2026, 07:35 AM
sb914 I’d go back to stock . Looks better and it’s a... Apr 16 2026, 08:04 AM
mepstein Yes but does it really matter if that’s what you... Apr 16 2026, 08:20 AM
914rrr
Yes but does it really matter if that’s what yo... Apr 16 2026, 09:32 AM
914rrr
Yes but does it really matter if that’s what yo... Apr 16 2026, 10:26 AM
jd74914 If you're so inclined...you can remove the tru... Apr 16 2026, 08:43 AM
Superhawk996 Doh Apr 16 2026, 11:03 AM
Superhawk996
If you're so inclined...you can remove the t... Apr 16 2026, 11:07 AM
Superhawk996 Doh! Apr 16 2026, 11:08 AM
rjames It would likely decrease the value of it unless it... Apr 16 2026, 10:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 04:42 PM |
