| peteinjp |
Apr 19 2026, 03:32 AM
Member ![]() ![]() Group: Members Posts: 213 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None
Narrow body 2.7 with 230ish hp. A052 195's on 6" wheels.
21mm hollow torsion bars in the front Bilstein raised spindle RSR struts Bilstien HD shocks Tarett 22mm front bar and links 150 lb springs rear Bilstein sport shocks Factory rear sway bar Patrick Motorsports adjustable tow link set for the rear What would you expect in terms of handling with this setup? No autocross- just hard driving on mountain roads. Pete |
| Superhawk996 |
Apr 19 2026, 06:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,788 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Always hard to tell based on specs alone and I’m not in the mood to do the math but that’s a lot of wheel rate in the front end between 21mm torsion bars and a 22mm anti roll bar.
I’ll put my bet in for plenty of understeer. |
peteinjp Curious what you guys would expect with suspension setup Apr 19 2026, 03:32 AM
mepstein Pretty miserable with the 21mm bars. Even mid 80â€... Apr 19 2026, 05:03 AM
Always hard to tell based on specs alone and I’... Apr 19 2026, 07:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th April 2026 - 05:06 PM |
