| TRP |
Jan 18 2026, 06:55 PM
Member ![]() ![]() Group: Members Posts: 445 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
This escalated quickly! 1.8 is out, getting ready ready for the 2056 to go in.
![]() I will start to clean up the engine bay and the underside of the car to prep for the new motor.] |
| TRP |
Apr 19 2026, 07:40 PM
Long day... but I managed to get some stuff done on the motor. A123 and GoWesty are in! New harness are sort of in. A lot of the hoses and wires are just laying on top of the motor until I figure out how I want to route everything. Seems like a shame to treat those new harnesses like that, Jeff did a BEAUTIFUL job on all three harnesses, they are beautiful. I am not really into the band clamps for the intake: they are big and clumsy looking. I am rying to figure out a better solution there, maybe just trimming the ends will make them less obnoxious? What do you all recommend?
![]() ![]() ![]() To do list: Weld on the afr bung Mount setrab oil cooler Get 15x6 Fuchs back from restoration Install fan, fan shroud Get 15" tires & install Adjust right trunk hinge to fix uneven gaps Repaint engine grills on engine cover install new P O R S C H E letters on engine cover Get new battery and install Finish MC install and bleed brakes Break in the cam (will break it in with carbs) Get harnesses back from El Jeffe Install alternator Install all the powder coated tins & gaskets Set thermostat cable/flaps Reassemble the ljet Figure out how to adapt and install the GoWesty throttle body Figure out how install A123 Distributor Up next Fill Transmission with fluid Install circuit board and heater blower Install Motor, exhaust Get it running in the car Wire up fan controller for oil cooler Wire up the afr sensor Wire up the cht sender & gauge Install new combo gauge It's coming along. It ain't much... I keep it clean though. |
TRP 1.8 is out... 2056 is in and it runs! Jan 18 2026, 06:55 PM
rfinegan WoooHooo, the real fun begins
Best Regards
-Rob... Jan 18 2026, 07:27 PM
TRP I hope I can get the new one back in! It's... Jan 18 2026, 08:23 PM
wonkipop you know i can't endorse you for rejecting the... Jan 19 2026, 01:52 AM
SirAndy I'm pretty sure we have a thread somewhere abo... Jan 19 2026, 09:52 AM
wonkipop
I'm pretty sure we have a thread somewhere ab... Jan 19 2026, 01:38 PM
TRP Haa! Yeah, it was hard to see through all the ... Jan 19 2026, 10:00 AM
SirAndy What's the name of the FI harness guru?
I alr... Jan 19 2026, 11:24 AM
TRP @wonkipop - sorry man, I'm weak... :D
Than... Jan 24 2026, 09:30 PM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jan 25 2026, 10:10 AM
TRP Here are some photos of the clean up work I starte... Jan 26 2026, 03:30 PM
TRP It's Sunday, so you know I have Updates.
Last... Feb 1 2026, 08:03 PM
TRP I reached out to Ken today, the rotating assembly ... Feb 9 2026, 08:49 PM
Chad911sc You can just mix up some fiberglass resin and clot... Feb 11 2026, 10:27 AM
Superhawk996
You can just mix up some fiberglass resin and clo... Feb 11 2026, 01:58 PM
bkrantz
[quote name='Chad911sc' post='3244712' date='Feb ... May 9 2026, 07:03 PM
TRP @Superhawk996 - I think [b]@[url=http://www.914w... Feb 11 2026, 03:57 PM
Superhawk996
@[url=http://www.914world.com/bbs2/index.php?show... Feb 11 2026, 04:59 PM
TRP Oh, no worries! I understand and appreciate an... Feb 11 2026, 05:49 PM
Superhawk996
One thing I hadn't considered is if replaci... Feb 11 2026, 07:44 PM
Chad911sc Yeah…lol.
That would be what the previous owner ... Feb 11 2026, 07:05 PM
TRP WHOA! Is that your car!? That looks like a... Feb 11 2026, 07:50 PM
Superhawk996
WHOA! Is that your car!? That looks like ... Feb 11 2026, 08:03 PM
Geezer914 Don't rush. Take your time and repair the rus... Feb 12 2026, 08:26 AM
TRP I got great news feom Ken Jansen yesterday! He... Mar 18 2026, 09:17 PM
TRP I keep finding things to keep me busy while I wait... Mar 29 2026, 10:08 AM
Chad911sc The 60’s Vette is Beautiful!
That color is P... Mar 31 2026, 10:11 AM
TRP Thank you! 1966, L79 C2 - Mosport Green/Green ... Mar 31 2026, 01:03 PM
Chad911sc The 123 distributor is pretty simple. Not sure abo... Mar 31 2026, 01:20 PM
TRP @[url=http://www.914world.com/bbs2/index.php?showu... Apr 6 2026, 11:57 AM
TRP Today could be the day I pick up the long block. ... Apr 10 2026, 08:27 AM
TRP ...sad trombone sounds... :WTF:
No joy on the... Apr 10 2026, 11:51 AM
porschetub
No joy on th... Apr 12 2026, 12:46 AM
930cabman Patience isn't always bad, recharge your batte... Apr 10 2026, 12:57 PM
TRP
Patience isn't always bad, recharge your batt... Apr 10 2026, 01:15 PM
TRP Here is what I was talking about:
I assume ... Apr 10 2026, 01:33 PM
Jack Standz IIRC the difference between the styles of tin and ... Apr 10 2026, 04:47 PM
TRP
We have a few racks mounted on the wall up by th... Apr 10 2026, 05:33 PM
Jack Standz Thinking the small hole alternator tin came on the... Apr 11 2026, 10:40 AM
TRP Thank you for the info @JackStands.
Today I was a... Apr 11 2026, 10:47 PM
TRP Thabk you @porschetub!
More progress today.... Apr 12 2026, 04:27 PM
TRP Updates, we got Updates!
I picked the motor u... Apr 19 2026, 08:29 AM
JamesJ
Long day... but I managed to get some stuff done ... May 10 2026, 01:10 PM
TRP Looking at these photos in again today and I reali... Apr 21 2026, 01:19 PM
Chad911sc The engine looks Beautiful!
Clean and tidy... Apr 21 2026, 02:51 PM
FlacaProductions If those clamps work great, keep 'em.
Form fol... Apr 21 2026, 04:02 PM
TRP Thanks for the info on the clamps and the kind wor... Apr 21 2026, 11:41 PM
wonkipop looks fab. super clean. :beer2:
as to the cl... Apr 22 2026, 01:43 PM
TRP
as to the c... Apr 22 2026, 02:05 PM
Cairo94507 Beautiful work. All I can add, and I am sure you ... Apr 22 2026, 02:03 PM
JeffBowlsby You might want to fasten the battery+ cable to the... Apr 22 2026, 04:48 PM
TRP
You might want to fasten the battery+ cable to th... Apr 22 2026, 06:22 PM
TRP Updates! We got updates! So today I wrapp... Apr 24 2026, 09:30 PM
porschetub
Updates! We got updates! So today I wrap... Apr 24 2026, 10:19 PM
TRP Thank you, I'm trying not to rush it.
I appre... Apr 24 2026, 10:33 PM
porschetub
I appr... Apr 25 2026, 02:11 PM
TRP
Pretty sure they are mounted upside down,cheers.... Apr 25 2026, 07:52 PM
TRP Today could be the day! Down to the ignition a... May 9 2026, 10:40 AM
HFC3 Motor almost deserves to just be a show piece. Stu... May 9 2026, 02:18 PM
TRP @HFC3 Thank you. It came together prettynwell.
... May 9 2026, 07:20 PM
TRP Still no joy. Won't fire up. I guess tomorrow ... May 9 2026, 10:11 PM
TRP Updates! We got updates...
Before doing anyth... May 10 2026, 04:42 PM
TRP @JamesJ - thank you. I like that look. I think ou... May 10 2026, 04:59 PM
JamesJ
[b]@[url=http://www.914world.com/bbs2/index.php?s... May 12 2026, 04:32 PM
fiacra Way to go Ted!!!! May 10 2026, 05:50 PM
wonkipop top stuff ted. :beer2:
if you want to get all... May 11 2026, 03:14 AM
Root_Werks Very cool! Be interested to get driving impre... May 12 2026, 12:07 PM
TRP Thank you all for your support and well wishes... May 12 2026, 01:04 PM
930cabman :headbanger: we love victories :headbanger... May 12 2026, 01:34 PM
Ninja Inside the AFM is where the AFM tension wheel is l... May 12 2026, 03:03 PM
TRP
Inside the AFM is where the AFM tension wheel is ... May 12 2026, 03:19 PM
fiacra
[quote name='Ninja' post='3256885' date='May 12 2... May 12 2026, 04:30 PM
TRP I buttoned up rerouting the oil lines, wired up th... May 16 2026, 08:25 PM
TRP The PE Industries wideband is AWESOME, I can see e... May 17 2026, 11:21 AM
FlacaProductions yeah - i love the PE with the app. Looks great... May 17 2026, 02:09 PM
TRP
yeah - i love the PE with the app. Looks great... May 20 2026, 05:37 PM
Root_Werks
yeah - i love the PE with the app. Looks great... May 21 2026, 09:20 AM
TRP Ohhh we got updates!
Woke up early, did some... May 21 2026, 11:47 AM
Root_Werks Don't be afraid to adjust (tiny amounts of cou... May 21 2026, 01:21 PM
TRP
Don't be afraid to adjust (tiny amounts of co... May 21 2026, 01:45 PM
FlacaProductions ok ok...ya got me.
Is this the link to the unit yo... May 21 2026, 02:27 PM
TRP
ok ok...ya got me.
Is this the link to the unit y... May 21 2026, 02:46 PM
fiacra Thanks for posting your progress. It has been fun... May 21 2026, 03:13 PM
TRP
Thanks for posting your progress. It has been fu... May 21 2026, 03:21 PM
TRP okay, latest update is that I'm running a pret... May 21 2026, 05:34 PM
TRP Wrapped up a bunch of final checks and double chec... May 31 2026, 05:59 PM
930cabman the joys of owning 50+ years old stuff :Qarl:... May 31 2026, 06:26 PM
TRP I wrapped up all of the known 'to do' item... Jun 7 2026, 09:35 PM
wonkipop
The most interesting part is that the car is sl... Jun 8 2026, 12:05 PM
TRP
The most interesting part is that the car is s... Jun 8 2026, 03:44 PM
wonkipop ah yes, forgot the 75 has that different valve.
th... Jun 8 2026, 04:02 PM
TRP Im going to hook the smoke machine back up in the ... Jun 8 2026, 04:24 PM
930cabman
Im going to hook the smoke machine back up in the... Jun 8 2026, 04:34 PM
TRP
Im going to hook the smoke machine back up in th... Jun 8 2026, 05:05 PM
930cabman
[quote name='930cabman' post='3260538' date='Jun ... Jun 8 2026, 07:06 PM
wonkipop
Im going to hook the smoke machine back up in the... Jun 8 2026, 05:19 PM
TRP Sooooo.... I have been trying and trying to get th... Jun 20 2026, 08:54 PM
wonkipop
Sooooo.... I have been trying and trying to get t... Jun 21 2026, 12:11 AM
TRP
I wonder if you can fit the older style decel val... Jun 21 2026, 03:39 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th September 2026 - 08:31 AM |
