| Stef914 |
Apr 21 2026, 11:24 PM
human ![]() ![]() Group: Members Posts: 118 Joined: 21-July 21 From: Los Angeles Member No.: 25,745 Region Association: Southern California |
Hi all,
Quick sanity check on injector install. I just installed a set of Standard Motor Products FJ67 injectors on my 2.0 D-Jet with brand new seals at the intake runners. What surprised me: * No “click” when inserting them * Only the tip went in * Final seating seemed to happen when tightening the retaining clamp They’re now sitting straight and look properly aligned, but I’m not fully confident they seated by hand before the clamp pulled them in. I can also still see a bit of the rubber seal sticking out at the base (see picture). I’ve only done one side so far, still need to do the passenger side, so I haven’t been able to run the engine and test for leaks yet. Is this normal with new seals on these cars? Should they fully seat by hand before the clamp goes on? Any risk of vacuum leaks if the clamp did part of the seating? For context, seals were installed dry. Thanks y’all |
| mgphoto |
Apr 22 2026, 12:17 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,501 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Looks correct, the rubber is an insulator so the gap is fine. The larger o-ring when placed correctly it puts the pressure on the port to prevent an air leak.
In this case only the tip goes in. |
Stef914 FJ67 injectors Apr 21 2026, 11:24 PM
DRPHIL914
Hi all,
... Apr 22 2026, 02:07 PM
Stef914 Thanks guys! There’s always that percentage ... Apr 22 2026, 03:36 PM
sithot Bill Johnson (Mr. Injector) approved. I'm run... Oct 12 2026, 01:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th October 2026 - 12:58 AM |
