| Wew |
Apr 23 2026, 08:57 AM
Member ![]() ![]() Group: Members Posts: 239 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
I have been reading many posts and doing lots of research and am throwing in the towel and putting this out to the brain trust. I rebuilt the transmission (Dr evil CD) and new clutch flywheel throw out bearing etc. Swepco transmission fluid. Shifting has always felt kind of stiff. After many shifter alignment issues and clutch adjustments, Checking to make sure clutch cable is not twisted around accelerator cable or a broken guide tube as I drove car I would notice it was much harder getting into 1st and reverse. So I tinkered again adjusted clutch cable and alignment. Now I can’t get reverse at all. Here’s the thing I notice with the clutch fork, it barely moves when tension is removed from clutch cable. It takes serious effort to move it by hand 1/8-1/4”. The car has sat for a while as I was sorting through other problems and other projects. For giggles I readjusted the shifter with a bias towards drivers side and still can’t get it into reverse. Is this clutch drag? If so what is the remedy other than dropping the transmission and redoing the clutch fork and throw out bearing. Thank you all for reading this long winded message and weighing in. |
| mlindner |
Apr 23 2026, 01:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,758 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
As Jack said, I bench tested mine and had to add a dime under the plastic bushing in the clutch fork to get the correct throw.
Wew No Reverse Apr 23 2026, 08:57 AM
mgphoto Did you resurface the flywheel, if so you should h... Apr 23 2026, 09:20 AM
Wew Thank you for the response. Flywheel is brand new... Apr 23 2026, 09:24 AM
Wew Ok. Adjusted cone screw and linkage behind firewal... Apr 23 2026, 01:14 PM
Jack Standz There is a small plastic bushing that resides in t... Apr 23 2026, 01:35 PM
Jack Standz Many years ago, back when that bushing wasn't ... Apr 23 2026, 01:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 23rd April 2026 - 03:45 PM |
