> Recommisioning a '73 Driver Project, making another 914 roadworthy again
Literati914
post Apr 8 2026, 03:13 PM
Couple months back I bought a Phoenix Red 1.7L '73 that I planned to do a "quick resto/refresh" on. The idea was to get it back on the road as a very descent driver, no rotisserie work or complete strip down for repaint. Mainly wanted to make it structurally and mechanically sound. I've been working on it and snapping a few pic as I go, so I thought I'd go ahead and post a thread about it here.
Literati914
post Apr 24 2026, 05:47 PM
Other side (IMG:style_emoticons/default/biggrin.gif)
Literati914   Recommisioning a '73 Driver Project   Apr 8 2026, 03:13 PM
Literati914   Basic Appearance: First of all, it obviously need...   Apr 8 2026, 03:33 PM
wonkipop   Basic Appearance: First of all, it obviously nee...   Apr 22 2026, 02:23 PM
Literati914   Obvious Issues: Leaning right rear wheel and a ri...   Apr 8 2026, 03:54 PM
930cabman   Obvious Issues: Leaning right rear wheel and a r...   Apr 8 2026, 06:11 PM
Literati914   Then it was on to the riveted license late that wa...   Apr 8 2026, 03:59 PM
Literati914   Repairs   Apr 8 2026, 04:06 PM
Literati914   Engine Compartment: The hell-hole is in great cond...   Apr 8 2026, 04:14 PM
Literati914   ..and the replacement tray   Apr 8 2026, 04:16 PM
Literati914   I also, weld/reinforced the engine lid brackets un...   Apr 8 2026, 04:18 PM
Literati914   There was a repair at the lower firewall area at t...   Apr 8 2026, 04:24 PM
Literati914   Then I turned my attention to the floors: I remove...   Apr 8 2026, 04:33 PM
Literati914   more examples -   Apr 8 2026, 04:35 PM
Literati914   Finally I added two coats of Chassis Saver rust pr...   Apr 8 2026, 04:38 PM
Literati914   I re-installed the cleaned up and re-sprayed trail...   Apr 8 2026, 04:46 PM
seanpaulmc   Good on you for bringing another one back! So ...   Apr 8 2026, 05:19 PM
Literati914   Good on you for bringing another one back! So...   Apr 8 2026, 05:42 PM
Literati914   New ear is great, how did you manage the "co...   Apr 8 2026, 07:30 PM
Literati914   Here's the other rocker, I did work on the rec...   Apr 8 2026, 07:34 PM
Literati914   The car was missing it's trunk torsion rods an...   Apr 8 2026, 07:38 PM
Literati914   I currently got the nose up to work on fuel tank e...   Apr 8 2026, 07:42 PM
dtmehall   it doesn't look like a creeper would work on t...   Apr 8 2026, 07:47 PM
Literati914   it doesn't look like a creeper would work on ...   Apr 8 2026, 08:29 PM
dtmehall   :( use lot's of voltaren!   Apr 8 2026, 08:34 PM
Literati914   I pulled the old original fuel lines and bent up s...   Apr 8 2026, 09:12 PM
Literati914   Installed   Apr 8 2026, 09:13 PM
slowrodent   This is clearly much more than a "quick refre...   Apr 9 2026, 07:22 AM
Literati914   The front areas of this car are pretty nice.. I cl...   Apr 9 2026, 09:41 AM
friethmiller   Nice work, @Literati914 . This thing will be bac...   Apr 9 2026, 09:54 AM
Literati914   I'd planned to do an internal cleaning of the ...   Apr 9 2026, 09:54 AM
Literati914   A new mesh screen is going back in too.   Apr 9 2026, 09:56 AM
Jamie   A new mesh screen is going back in too. Those in...   Apr 9 2026, 10:58 AM
Literati914   Those internal screens are so useless! I dest...   Apr 9 2026, 11:18 AM
Literati914   As mentioned earlier someone had altered the fuse ...   Apr 21 2026, 03:01 PM
Literati914   Grabbed a spare OEM fuse holder and reinstalled it...   Apr 21 2026, 03:02 PM
Literati914   The real problem was the unorganized nest of wirin...   Apr 21 2026, 03:05 PM
Literati914   There were many issues, particularly with the ligh...   Apr 21 2026, 03:09 PM
Literati914   Now we have this at both sides. Hopefully I can ge...   Apr 21 2026, 03:11 PM
Literati914   I tested the original speedo cable and it was not ...   Apr 21 2026, 03:17 PM
Literati914   Speedometer cable installed. Note in this pic, the...   Apr 21 2026, 03:20 PM
Literati914   Then I moved to the wiring for the brake warning s...   Apr 21 2026, 03:22 PM
Literati914   Got that repaired, and re-taped the whole area.   Apr 21 2026, 03:24 PM
Literati914   Next on the agenda - As I had mentioned the heat/d...   Apr 21 2026, 03:29 PM
bkrantz   Great work! I am curious how the suspension e...   Apr 21 2026, 07:15 PM
Literati914   Great work! I am curious how the suspension ...   Apr 21 2026, 10:31 PM
wonkipop   phoenix red. what a great color :beer2: . keep ...   Apr 22 2026, 04:12 AM
Literati914   Wiring reconnected and put back into place.   Apr 22 2026, 01:28 PM
Literati914   Slider unit and FSB light back in..   Apr 22 2026, 01:30 PM
Literati914   Great. Except after I went through removing the cu...   Apr 22 2026, 01:40 PM
Literati914   So then I got to do this (fun! :angry: )   Apr 22 2026, 01:41 PM
Artfrombama   Great restoration thread, thanks for documenting t...   Apr 22 2026, 02:46 PM
Literati914   .. yeah that steering wheel is interesting if it ...   Apr 23 2026, 10:35 AM
wonkipop   @[url=http://www.914world.com/bbs2/index.php?showu...   Apr 23 2026, 01:24 PM
Literati914   I managed to get the defrost unit replaced, cables...   Apr 24 2026, 08:47 AM
Literati914   Time to re-install the fuel tank… not so fast, b...   Apr 24 2026, 08:51 AM
Literati914   Tank back in.   Apr 24 2026, 08:52 AM
Literati914   The harness in the frunk was bothering me with all...   Apr 24 2026, 08:53 AM
Literati914   So I cleaned it up and re-taped it. Ps - note in ...   Apr 24 2026, 08:58 AM
Literati914   Both the areas by the headlight motors looked like...   Apr 24 2026, 05:44 PM
Literati914   So I cleaned these areas up and probably avoided a...   Apr 24 2026, 05:46 PM
Literati914   Other side :D   Apr 24 2026, 05:47 PM
Literati914   Moved to the back and cleaned up and installed the...   Apr 25 2026, 12:38 PM
Literati914   The right side   Apr 25 2026, 12:40 PM
Literati914   Wires going back to the trunk were in a sorry stat...   Apr 25 2026, 12:43 PM
Literati914   Cleaned up, re-taped.. and now reinstalled   Apr 25 2026, 12:44 PM
Literati914   Which leads me to tail lights. The right side tail...   Apr 27 2026, 07:31 PM
Literati914   The thin seals around the lenses were both deterio...   Apr 27 2026, 07:33 PM
Literati914   Jumped up to the front and cleaned up the suspensi...   Apr 27 2026, 07:41 PM
Literati914   The targa top on this car was in bad shape. The fi...   May 29 2026, 09:02 PM
Literati914   After sanding smooth and some filler, this pic is ...   May 29 2026, 09:04 PM
Literati914   I picked up a 1 gal. Herculiner roll-on kit, unuse...   May 29 2026, 09:10 PM
Literati914   The kit came with textured rollers and I did use s...   May 29 2026, 09:14 PM
Literati914   I had left over bed liner and decided to coat the ...   Jun 5 2026, 10:20 AM
Literati914   I roughed up the surface and applied it over the o...   Jun 5 2026, 10:26 AM
Literati914   I added hydraulic hood support struts to the front...   Jun 7 2026, 07:10 PM
Literati914   So much better imho, now that I’m not hearing th...   Jun 7 2026, 07:15 PM
HFC3   Great job!   Jun 8 2026, 06:51 PM
Literati914   Started reinstalling the interior. Seat belts are ...   Jun 10 2026, 02:29 PM
Literati914   The Backpad needed some love just to make it usabl...   Jun 10 2026, 02:34 PM
Literati914   Front side. The tabs on the reverse side are solid...   Jun 10 2026, 02:38 PM
Literati914   .. and solidly installed now :Qarl:   Jun 10 2026, 02:42 PM
Literati914   Been a while since I posted on this project.. but ...   Oct 11 2026, 07:01 PM
Literati914   I even had enough to get some inside both doors :...   Oct 11 2026, 07:04 PM
gereed75   I really love these kind of functional restoration...   Oct 12 2026, 04:59 AM
Literati914   I installed some thick automotive carpet pad/under...   Oct 24 2026, 03:44 PM
Literati914   Oh yea, I also installed the center seat belt latc...   Oct 24 2026, 04:06 PM
Literati914   I mean, this should work electrically, and they ce...   Oct 24 2026, 04:10 PM
Literati914   The front valance on this car was a mess - pretty ...   Nov 23 2026, 07:17 PM
Literati914   Forgot to get an after pic, but it came out nice a...   Nov 23 2026, 07:19 PM
Literati914   Been jumping all over the place on this car.. I go...   Nov 23 2026, 07:24 PM
Literati914   Engine de-tinned and before clean up   Nov 23 2026, 07:26 PM
Literati914   Cleaned up, going back together w/ a new oil coole...   Nov 23 2026, 07:28 PM
Literati914   Transmission got seals replaced, including the lit...   Nov 23 2026, 07:33 PM
Literati914   Then I jumped over and installed the fuel pump tha...   Nov 23 2026, 07:43 PM
Literati914   Kept feeling like there was something else I neede...   Nov 23 2026, 07:46 PM
Literati914   So I dug out as much old grease as possible, clean...   Nov 23 2026, 07:48 PM
worn   This is turning out to be a very desirable sports ...   Nov 24 2026, 07:01 PM
Root_Werks   Progress is looking good!   Nov 25 2026, 12:25 PM
- Lo-Fi Version Time is now: 25th November 2026 - 11:46 PM
