> 1.8 is out... 2056 is in and it runs!, It's a runner! Wahhooo!
TRP
post Jan 18 2026, 06:55 PM
This escalated quickly! 1.8 is out, getting ready ready for the 2056 to go in.
I will start to clean up the engine bay and the underside of the car to prep for the new motor.]
TRP
post Apr 24 2026, 09:30 PM
Updates! We got updates! So today I wrapped up a bunch of little ods and ends and then I figured it was time to put the motor back in.
Taking it slowly and double checking everything along the way.
To do list:
Weld on the afr bung
Mount setrab oil cooler
Get 15x6 Fuchs back from restoration
Install fan, fan shroud
Get 15" tires & install
Adjust right trunk hinge to fix uneven gaps
Repaint engine grills on engine cover
install new P O R S C H E letters on engine cover
Get new battery and install
Finish MC install and bleed brakes
Break in the cam (will break it in with carbs)
Get harnesses back from El Jeffe
Install alternator
Install all the powder coated tins & gaskets
Set thermostat cable/flaps
Reassemble the ljet
Figure out how to adapt and install the GoWesty throttle body
Figure out how install A123 Distributor
Fill Transmission with fluid
Install circuit board and heater blower
Install Motor
Up next
Install exhaust & heat parts
Get motor running in the car
Wire up fan controller for oil cooler
Wire up the afr sensor
Wire up the cht sender & gauge
Install new combo gauge
TRP   1.8 is out... 2056 is in and it runs!   Jan 18 2026, 06:55 PM
rfinegan   WoooHooo, the real fun begins Best Regards -Rob...   Jan 18 2026, 07:27 PM
TRP   I hope I can get the new one back in! It's...   Jan 18 2026, 08:23 PM
wonkipop   you know i can't endorse you for rejecting the...   Jan 19 2026, 01:52 AM
SirAndy   I'm pretty sure we have a thread somewhere abo...   Jan 19 2026, 09:52 AM
wonkipop   I'm pretty sure we have a thread somewhere ab...   Jan 19 2026, 01:38 PM
TRP   Haa! Yeah, it was hard to see through all the ...   Jan 19 2026, 10:00 AM
SirAndy   What's the name of the FI harness guru? I alr...   Jan 19 2026, 11:24 AM
TRP   @wonkipop - sorry man, I'm weak... :D Than...   Jan 24 2026, 09:30 PM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jan 25 2026, 10:10 AM
TRP   Here are some photos of the clean up work I starte...   Jan 26 2026, 03:30 PM
TRP   It's Sunday, so you know I have Updates. Last...   Feb 1 2026, 08:03 PM
TRP   I reached out to Ken today, the rotating assembly ...   Feb 9 2026, 08:49 PM
Chad911sc   You can just mix up some fiberglass resin and clot...   Feb 11 2026, 10:27 AM
Superhawk996   You can just mix up some fiberglass resin and clo...   Feb 11 2026, 01:58 PM
bkrantz   [quote name='Chad911sc' post='3244712' date='Feb ...   May 9 2026, 07:03 PM
TRP   @Superhawk996 - I think [b]@[url=http://www.914w...   Feb 11 2026, 03:57 PM
Superhawk996   @[url=http://www.914world.com/bbs2/index.php?show...   Feb 11 2026, 04:59 PM
TRP   Oh, no worries! I understand and appreciate an...   Feb 11 2026, 05:49 PM
Superhawk996   One thing I hadn't considered is if replaci...   Feb 11 2026, 07:44 PM
Chad911sc   Yeah…lol. That would be what the previous owner ...   Feb 11 2026, 07:05 PM
TRP   WHOA! Is that your car!? That looks like a...   Feb 11 2026, 07:50 PM
Superhawk996   WHOA! Is that your car!? That looks like ...   Feb 11 2026, 08:03 PM
Geezer914   Don't rush. Take your time and repair the rus...   Feb 12 2026, 08:26 AM
TRP   I got great news feom Ken Jansen yesterday! He...   Mar 18 2026, 09:17 PM
TRP   I keep finding things to keep me busy while I wait...   Mar 29 2026, 10:08 AM
Chad911sc   The 60’s Vette is Beautiful! That color is P...   Mar 31 2026, 10:11 AM
TRP   Thank you! 1966, L79 C2 - Mosport Green/Green ...   Mar 31 2026, 01:03 PM
Chad911sc   The 123 distributor is pretty simple. Not sure abo...   Mar 31 2026, 01:20 PM
TRP   @[url=http://www.914world.com/bbs2/index.php?showu...   Apr 6 2026, 11:57 AM
TRP   Today could be the day I pick up the long block. ...   Apr 10 2026, 08:27 AM
TRP   ...sad trombone sounds... :WTF: No joy on the...   Apr 10 2026, 11:51 AM
porschetub   ...sad trombone sounds... :WTF: No joy on th...   Apr 12 2026, 12:46 AM
930cabman   Patience isn't always bad, recharge your batte...   Apr 10 2026, 12:57 PM
TRP   Patience isn't always bad, recharge your batt...   Apr 10 2026, 01:15 PM
TRP   Here is what I was talking about: I assume ...   Apr 10 2026, 01:33 PM
Jack Standz   IIRC the difference between the styles of tin and ...   Apr 10 2026, 04:47 PM
TRP   We have a few racks mounted on the wall up by th...   Apr 10 2026, 05:33 PM
Jack Standz   Thinking the small hole alternator tin came on the...   Apr 11 2026, 10:40 AM
TRP   Thank you for the info @JackStands. Today I was a...   Apr 11 2026, 10:47 PM
TRP   Thabk you @porschetub! More progress today....   Apr 12 2026, 04:27 PM
TRP   Updates, we got Updates! I picked the motor u...   Apr 19 2026, 08:29 AM
TRP   Long day... but I managed to get some stuff done o...   Apr 19 2026, 07:40 PM
JamesJ   Long day... but I managed to get some stuff done ...   May 10 2026, 01:10 PM
TRP   Looking at these photos in again today and I reali...   Apr 21 2026, 01:19 PM
Chad911sc   The engine looks Beautiful! Clean and tidy...   Apr 21 2026, 02:51 PM
FlacaProductions   If those clamps work great, keep 'em. Form fol...   Apr 21 2026, 04:02 PM
TRP   Thanks for the info on the clamps and the kind wor...   Apr 21 2026, 11:41 PM
wonkipop   looks fab. super clean. :beer2: as to the cl...   Apr 22 2026, 01:43 PM
TRP   looks fab. super clean. :beer2: as to the c...   Apr 22 2026, 02:05 PM
Cairo94507   Beautiful work. All I can add, and I am sure you ...   Apr 22 2026, 02:03 PM
JeffBowlsby   You might want to fasten the battery+ cable to the...   Apr 22 2026, 04:48 PM
TRP   You might want to fasten the battery+ cable to th...   Apr 22 2026, 06:22 PM
TRP   Updates! We got updates! So today I wrapp...   Apr 24 2026, 09:30 PM
porschetub   Updates! We got updates! So today I wrap...   Apr 24 2026, 10:19 PM
TRP   Thank you, I'm trying not to rush it. I appre...   Apr 24 2026, 10:33 PM
porschetub   Thank you, I'm trying not to rush it. I appr...   Apr 25 2026, 02:11 PM
TRP   Pretty sure they are mounted upside down,cheers....   Apr 25 2026, 07:52 PM
TRP   Today could be the day! Down to the ignition a...   May 9 2026, 10:40 AM
HFC3   Motor almost deserves to just be a show piece. Stu...   May 9 2026, 02:18 PM
TRP   @HFC3 Thank you. It came together prettynwell. ...   May 9 2026, 07:20 PM
TRP   Still no joy. Won't fire up. I guess tomorrow ...   May 9 2026, 10:11 PM
TRP   Updates! We got updates... Before doing anyth...   May 10 2026, 04:42 PM
TRP   @JamesJ - thank you. I like that look. I think ou...   May 10 2026, 04:59 PM
JamesJ   [b]@[url=http://www.914world.com/bbs2/index.php?s...   May 12 2026, 04:32 PM
fiacra   Way to go Ted!!!!   May 10 2026, 05:50 PM
wonkipop   top stuff ted. :beer2: if you want to get all...   May 11 2026, 03:14 AM
Root_Werks   Very cool! Be interested to get driving impre...   May 12 2026, 12:07 PM
TRP   Thank you all for your support and well wishes...   May 12 2026, 01:04 PM
930cabman   :headbanger: we love victories :headbanger...   May 12 2026, 01:34 PM
Ninja   Inside the AFM is where the AFM tension wheel is l...   May 12 2026, 03:03 PM
TRP   Inside the AFM is where the AFM tension wheel is ...   May 12 2026, 03:19 PM
fiacra   [quote name='Ninja' post='3256885' date='May 12 2...   May 12 2026, 04:30 PM
TRP   I buttoned up rerouting the oil lines, wired up th...   May 16 2026, 08:25 PM
TRP   The PE Industries wideband is AWESOME, I can see e...   May 17 2026, 11:21 AM
FlacaProductions   yeah - i love the PE with the app. Looks great...   May 17 2026, 02:09 PM
TRP   yeah - i love the PE with the app. Looks great...   May 20 2026, 05:37 PM
Root_Werks   yeah - i love the PE with the app. Looks great...   May 21 2026, 09:20 AM
TRP   Ohhh we got updates! Woke up early, did some...   May 21 2026, 11:47 AM
Root_Werks   Don't be afraid to adjust (tiny amounts of cou...   May 21 2026, 01:21 PM
TRP   Don't be afraid to adjust (tiny amounts of co...   May 21 2026, 01:45 PM
FlacaProductions   ok ok...ya got me. Is this the link to the unit yo...   May 21 2026, 02:27 PM
TRP   ok ok...ya got me. Is this the link to the unit y...   May 21 2026, 02:46 PM
fiacra   Thanks for posting your progress. It has been fun...   May 21 2026, 03:13 PM
TRP   Thanks for posting your progress. It has been fu...   May 21 2026, 03:21 PM
TRP   okay, latest update is that I'm running a pret...   May 21 2026, 05:34 PM
TRP   Wrapped up a bunch of final checks and double chec...   May 31 2026, 05:59 PM
930cabman   the joys of owning 50+ years old stuff :Qarl:...   May 31 2026, 06:26 PM
TRP   I wrapped up all of the known 'to do' item...   Jun 7 2026, 09:35 PM
wonkipop   The most interesting part is that the car is sl...   Jun 8 2026, 12:05 PM
TRP   The most interesting part is that the car is s...   Jun 8 2026, 03:44 PM
wonkipop   ah yes, forgot the 75 has that different valve. th...   Jun 8 2026, 04:02 PM
TRP   Im going to hook the smoke machine back up in the ...   Jun 8 2026, 04:24 PM
930cabman   Im going to hook the smoke machine back up in the...   Jun 8 2026, 04:34 PM
TRP   Im going to hook the smoke machine back up in th...   Jun 8 2026, 05:05 PM
930cabman   [quote name='930cabman' post='3260538' date='Jun ...   Jun 8 2026, 07:06 PM
wonkipop   Im going to hook the smoke machine back up in the...   Jun 8 2026, 05:19 PM
TRP   Sooooo.... I have been trying and trying to get th...   Jun 20 2026, 08:54 PM
wonkipop   Sooooo.... I have been trying and trying to get t...   Jun 21 2026, 12:11 AM
TRP   I wonder if you can fit the older style decel val...   Jun 21 2026, 03:39 PM
- Lo-Fi Version Time is now: 8th September 2026 - 08:32 AM
