> Charging Issue?, I'm terrible at solving electrical problems
sdoolin
post Apr 25 2026, 11:05 AM
Voltmeter shows between 10V - 12V at idle (and everywhere else). Voltmeter drops to 10V when headlights, flashers, and wipers switched on. Multimeter across the battery terminals at idle reads 12.5V.
Alternator was verified good several years back when I built this engine.
I'm not sure what to check next?
sdoolin
post Apr 25 2026, 11:56 AM
OK, so I checked some more things, and I am NOT GOOD with a multimeter. But, here's what I found (all measurements at idle):
Battery = 12.5V
Green Wire from alternator and chassis ground = 4.5V
Brown wire from alternator and chassis ground = 0.05V (essentially 0)
Red wire from alternator and chassis ground = 13.8V
fixer34
post Apr 25 2026, 03:35 PM
QUOTE(sdoolin @ Apr 25 2026, 12:56 PM) *
Battery = 12.5V
Assume red wire to chassis ground reading is being made at the battery positive terminal while the engine is running? Do the same measurement across the actual battery terminals. Voltage reading should be the same, or very close.
If it isn't, check/clean the battery terminal connections, the red wire connection to the positive post, the ground strap from battery to chassis, and the chassis strap underneath to the transmission. Unbolt and make sure the connections are clean/shiny.
6 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
1 Members: PanelBilly
- Lo-Fi Version Time is now: 25th April 2026 - 07:36 PM
