| sdoolin |
Apr 25 2026, 11:05 AM
Member ![]() ![]() Group: Members Posts: 421 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Voltmeter shows between 10V - 12V at idle (and everywhere else). Voltmeter drops to 10V when headlights, flashers, and wipers switched on. Multimeter across the battery terminals at idle reads 12.5V.
Alternator was verified good several years back when I built this engine. I'm not sure what to check next? |
| sdoolin |
Apr 25 2026, 04:13 PM
Battery is virtually new, and lives on a trickle charger when not being driven. Terminals clean and tidy. All grounds clean and tidy and nice and tight.
Red wire measurement is between the wire/terminal and the chassis ground that lives next to the relay board. |
| fixer34 |
Apr 25 2026, 08:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Battery is virtually new, and lives on a trickle charger when not being driven. Terminals clean and tidy. All grounds clean and tidy and nice and tight. Red wire measurement is between the wire/terminal and the chassis ground that lives next to the relay board. Verify at those spots again, then check at the battery terminals. Readings should be the same. |
sdoolin Charging Issue? Apr 25 2026, 11:05 AM
mgphoto
Voltmeter shows between 10V - 12V at idle (and ev... Apr 25 2026, 11:30 AM
sdoolin OK, so I checked some more things, and I am NOT GO... Apr 25 2026, 11:56 AM
fixer34
OK, so I checked some more things, and I am NOT G... Apr 25 2026, 03:35 PM
Spoke
OK, so I checked some more things, and I am NOT G... Apr 25 2026, 08:55 PM
mgphoto 13.8 your alternator looks to be ok but your batte... Apr 25 2026, 02:58 PM
mgphoto
Battery is virtually new, and lives on a trickle ... Apr 25 2026, 06:25 PM
930cabman Is the voltage in the 13.5 - 15v when running?
I... Apr 25 2026, 06:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th April 2026 - 11:04 PM |
