| VaccaRabite |
Apr 26 2026, 07:29 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,852 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
This is for my 1972 bus, but it’s very similar to a carbed 914. I am in a no start situation.
1.7 Type4 engine. 123Ignition dizzy (new) New 12v coil - 3.6 ohm Voltage from terminal 15 (+) on coil to ground is ~9 volts. Voltage from terminal 1 (-) on coil to ground is 12.6 volts (battery voltage) If I run a jumper from 15 to ground I get 12.6 volts - but still no start. So- I’m getting voltage drop somewhere. Plug wires are spiral wound wires. I tested the resistance of the center wire (dizzy to coil) and it was 767 ohms. Wire is about a foot long, so that is in spec. The green light in the 123Ignition turns on if I spin the body. So not only am I pretty sure the unit is getting power, but I’m also pretty sure the timing is close enough that I should get it to start. 123Ignition is wired correctly. Red to 15, black to 1 on coil. Fuel pump is also running through the coil and it runs solidly on key on, and key off but jumper end from battery + to post 15 on the coil. I have tried removing the tach and fuel pump wires - no help. I don’t think this is a 123Ignition problem. I think this is a bus wiring problem. History - bus was running AWESOME. Went for a 120 mile drive, but before I got out of my neighborhood I started missing bad and limped home a couple miles on 2-3 cylinders. This was back in December. I tested the coil and it was reading 2ohms across the primaries so I figured I had blown up my points (points generally want 3+ ohms). I now think my points were likely fine, and I am dealing with a bad wire or a bad ground somewhere. Okay brain trust. What you got? Thanks Zach |
| Superhawk996 |
Apr 26 2026, 10:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,821 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I’m also confused about the fuel pump.
You say you removed the pump wires and tach wires from the coil but it made no difference. But then how were you powering the fuel pump? And when the fuel pump was removed from the coil were you still measuring 9v on coil terminal 15? |
VaccaRabite Type 4 ignition issues Apr 26 2026, 07:29 PM
Superhawk996 Confused. You mention 123 dizzy but then talk abo... Apr 26 2026, 10:06 PM
Superhawk996 Let’s just put the 123 dizzy schematic here for ... Apr 26 2026, 10:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 27th April 2026 - 05:46 AM |
