> Type 4 ignition issues
VaccaRabite
post Apr 26 2026, 07:29 PM
En Garde!
This is for my 1972 bus, but it’s very similar to a carbed 914. I am in a no start situation.
1.7 Type4 engine.
123Ignition dizzy (new)
New 12v coil - 3.6 ohm
Voltage from terminal 15 (+) on coil to ground is ~9 volts.
Voltage from terminal 1 (-) on coil to ground is 12.6 volts (battery voltage)
If I run a jumper from 15 to ground I get 12.6 volts - but still no start. So- I’m getting voltage drop somewhere.
Plug wires are spiral wound wires. I tested the resistance of the center wire (dizzy to coil) and it was 767 ohms. Wire is about a foot long, so that is in spec.
The green light in the 123Ignition turns on if I spin the body. So not only am I pretty sure the unit is getting power, but I’m also pretty sure the timing is close enough that I should get it to start.
123Ignition is wired correctly. Red to 15, black to 1 on coil.
Fuel pump is also running through the coil and it runs solidly on key on, and key off but jumper end from battery + to post 15 on the coil.
I have tried removing the tach and fuel pump wires - no help.
I don’t think this is a 123Ignition problem. I think this is a bus wiring problem.
History - bus was running AWESOME. Went for a 120 mile drive, but before I got out of my neighborhood I started missing bad and limped home a couple miles on 2-3 cylinders. This was back in December. I tested the coil and it was reading 2ohms across the primaries so I figured I had blown up my points (points generally want 3+ ohms). I now think my points were likely fine, and I am dealing with a bad wire or a bad ground somewhere.
Okay brain trust. What you got?
Thanks
Zach
Superhawk996
post Apr 26 2026, 10:45 PM
Let’s just put the 123 dizzy schematic here for clarity.
For clarity I’m going to assume the 123 dizzy you have isn’t the POS option and doesn’t even have the blue wire. Similarly assuming that since your carbed, there are no wires for fuel injection trigger points.
- Lo-Fi Version Time is now: 27th April 2026 - 05:45 AM
