| DRPHIL914 |
Apr 29 2026, 08:44 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,926 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
When I removed the harness when pulling the motor I pulled one of the wires out of the small round end that the 2 wires use to push into the back up light switch, so the question is how do I put that wire back into the ball like end ? I tried using a crimper but it is out of shape and cant get pushed into the socket. im sure there is probably a special crimper to use that type of connector ?
Philip |
| Luke M |
Apr 29 2026, 09:00 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,503 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
When I removed the harness when pulling the motor I pulled one of the wires out of the small round end that the 2 wires use to push into the back up light switch, so the question is how do I put that wire back into the ball like end ? I tried using a crimper but it is out of shape and cant get pushed into the socket. im sure there is probably a special crimper to use that type of connector ? Philip Sounds like the terminal has pulled out of the wire correct? If so then strip the wire back and solder it together. Pretty sure these are soldered from the factory. |
| DRPHIL914 |
Apr 29 2026, 09:06 AM
When I removed the harness when pulling the motor I pulled one of the wires out of the small round end that the 2 wires use to push into the back up light switch, so the question is how do I put that wire back into the ball like end ? I tried using a crimper but it is out of shape and cant get pushed into the socket. im sure there is probably a special crimper to use that type of connector ? Philip Sounds like the terminal has pulled out of the wire correct? If so then strip the wire back and solder it together. Pretty sure these are soldered from the factory. Luke, Yes, it pulled out of the connector. Yes i can solder that back in there, should have done that with it out of the car lol but i can do that . Thanks for the suggestion |
DRPHIL914 back up light connection at the switch in the transmission Apr 29 2026, 08:44 AM
930cabman
When I removed the harness when pulling the moto... Apr 29 2026, 11:01 AM
mgphoto
When I removed the harness when pulling the motor... Apr 29 2026, 09:08 AM
jim_hoyland Be sure the pin is there⦠:) Apr 29 2026, 10:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 12:11 PM |
