| DRPHIL914 |
Apr 29 2026, 08:44 AM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,926 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
When I removed the harness when pulling the motor I pulled one of the wires out of the small round end that the 2 wires use to push into the back up light switch, so the question is how do I put that wire back into the ball like end ? I tried using a crimper but it is out of shape and cant get pushed into the socket. im sure there is probably a special crimper to use that type of connector ?
Philip |
| mgphoto |
Apr 29 2026, 09:08 AM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,463 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
When I removed the harness when pulling the motor I pulled one of the wires out of the small round end that the 2 wires use to push into the back up light switch, so the question is how do I put that wire back into the ball like end ? I tried using a crimper but it is out of shape and cant get pushed into the socket. im sure there is probably a special crimper to use that type of connector ? Philip Large blob of solder on the tip of the wire, a little shaping and push into place. |
DRPHIL914 back up light connection at the switch in the transmission Apr 29 2026, 08:44 AM
Luke M
When I removed the harness when pulling the motor... Apr 29 2026, 09:00 AM
DRPHIL914
When I removed the harness when pulling the moto... Apr 29 2026, 09:06 AM
930cabman
When I removed the harness when pulling the moto... Apr 29 2026, 11:01 AM
jim_hoyland Be sure the pin is there⦠:) Apr 29 2026, 10:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 29th April 2026 - 12:11 PM |
