| Tdskip |
Apr 30 2026, 01:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,770 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
So as some of you may remember, I’ve been battling a shifting issue that I diagnosed as an improperly rebuilt transmission so I bought a replacement one from Bruce (that had been rebuilt by our very own Dr Evil) I’m having the same issues getting gears with the engine running. New coupler, bushings good, shifter adjusted properly, clutch linkage not bent etc…
So that means my inability to get gears is most likely the clutch tube flopping around. It appears I need to open up the tunnel and I wanted to ask if where my finger is pointing is the right spot to make a cut? Thanks! |
930cabman No pics, but I took out a whole section about 3... Apr 30 2026, 01:18 PM
JeffBowlsby STRONGLY recommend that you remove the shifter, an... Apr 30 2026, 01:35 PM
Tdskip
STRONGLY recommend that you remove the shifter, a... Apr 30 2026, 01:45 PM
dr914@autoatlanta.com there is a diagram in the appendix of the tech tip... Apr 30 2026, 02:02 PM
Tdskip
there is a diagram in the appendix of the tech ti... Apr 30 2026, 02:16 PM
barefoot here's where I cut open to get access to the f... Apr 30 2026, 03:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 08:01 PM |
