> Where to make the cut on a clutch tube repair?
Tdskip
post Apr 30 2026, 01:14 PM
So as some of you may remember, I’ve been battling a shifting issue that I diagnosed as an improperly rebuilt transmission so I bought a replacement one from Bruce (that had been rebuilt by our very own Dr Evil) I’m having the same issues getting gears with the engine running. New coupler, bushings good, shifter adjusted properly, clutch linkage not bent etc…
So that means my inability to get gears is most likely the clutch tube flopping around. It appears I need to open up the tunnel and I wanted to ask if where my finger is pointing is the right spot to make a cut?
Thanks!
barefoot
post Apr 30 2026, 03:44 PM
here's where I cut open to get access to the front bracket,
enlarged the opening between 2 round ports ;
BTW I just used a clamp intended for electrical conduit, took a little blacksmithing
to get correct curvature (a 3/8 extension was perfect anvil) then 1/4" bolt, no welding
Barefoot
- Lo-Fi Version Time is now: 30th April 2026 - 08:02 PM
