| jacktarnold |
May 3 2026, 01:20 PM
Newbie ![]() Group: Members Posts: 5 Joined: 23-October 20 From: Arizona Member No.: 24,799 Region Association: Southwest Region |
Hi all,
Looking for some guidance before I go too far down the rabbit hole. I’ve got a 1973 914 2.0 that I’m bringing back after about 10 years off the road. I’ve gone through the fuel system and brakes, got it running, and took it out for a short test drive. Issue: I could never find 4th or 5th gear. I started working through the shift linkage by checking bushings and alignment and found that the rear shift rod retaining screw appears to have been previously repaired with a Helicoil. Unfortunately, that insert is now backing out, so the connection isn’t solid. Before I start tearing deeper into it, I’m trying to figure out the best path forward: * Is it worth redoing the Helicoil, or should I go another route? * Any preferred repair methods for this specific location that hold up long-term? Appreciate any advice or lessons learned |
| Shivers |
May 3 2026, 02:56 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,370 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi all, Looking for some guidance before I go too far down the rabbit hole. I’ve got a 1973 914 2.0 that I’m bringing back after about 10 years off the road. I’ve gone through the fuel system and brakes, got it running, and took it out for a short test drive. Issue: I could never find 4th or 5th gear. I started working through the shift linkage by checking bushings and alignment and found that the rear shift rod retaining screw appears to have been previously repaired with a Helicoil. Unfortunately, that insert is now backing out, so the connection isn’t solid. Before I start tearing deeper into it, I’m trying to figure out the best path forward: * Is it worth redoing the Helicoil, or should I go another route? * Any preferred repair methods for this specific location that hold up long-term? Appreciate any advice or lessons learned a time sert would be the fix in my opinion. It really is better than the spring. https://www.timesert.com/ |
jacktarnold Can’t Find 4th/5th + Shift Linkage Issue (Helicoil Failure) May 3 2026, 01:20 PM
Jack Standz New couplers are pretty expensive, so you could p... May 3 2026, 02:41 PM
FlacaProductions Put a WTB up - I'm sure someone has one - or s... May 3 2026, 03:00 PM
930cabman :wttc:
I would consider this: https://tangeriner... May 3 2026, 03:03 PM
JamesM
:wttc:
I would consider this: [url=https://tang... May 3 2026, 03:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd May 2026 - 04:34 PM |
