> Can’t Find 4th/5th + Shift Linkage Issue (Helicoil Failure)
jacktarnold
post May 3 2026, 01:20 PM
Hi all,
Looking for some guidance before I go too far down the rabbit hole.
I’ve got a 1973 914 2.0 that I’m bringing back after about 10 years off the road. I’ve gone through the fuel system and brakes, got it running, and took it out for a short test drive.
Issue: I could never find 4th or 5th gear.
I started working through the shift linkage by checking bushings and alignment and found that the rear shift rod retaining screw appears to have been previously repaired with a Helicoil. Unfortunately, that insert is now backing out, so the connection isn’t solid.
Before I start tearing deeper into it, I’m trying to figure out the best path forward:
* Is it worth redoing the Helicoil, or should I go another route?
* Any preferred repair methods for this specific location that hold up long-term?
Appreciate any advice or lessons learned
FlacaProductions
post May 3 2026, 03:00 PM
Put a WTB up - I'm sure someone has one - or someone here on this thread will speak up.
5 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 3rd May 2026 - 04:36 PM
