| mlw914 |
May 8 2026, 05:37 PM
Newbie ![]() Group: Members Posts: 4 Joined: 6-November 24 From: Los Gatos, CA Member No.: 28,449 Region Association: Northern California |
Hello 914W,
I am going to update the suspension in my '73 914 6 conversion. It's got a 3.0l in it, dual PMO's, Cayman 4 piston calipers and 911 discs, 321 ignition, Patrick Motorsports conversion kit and front oil cooler kit, running 16" Ultralights to accommodate the brake rotors. Sway bars F & R as well. I am doing some suspension upgrades and wanted suggestions on what suspension components you all would suggest. I am leaning towards Bilstein units but not sure. I also wanted to know from those with more experience and knowledge regarding the parking brake setup. Obviously with the Cayman calipers I can't use the old system and its gone. What have you done or seen done to allow for an e brake? Don't get me wrong, my $7 Harbor Freight wheel chock is working great, just not an ideal setup. I have heard of compression lock systems and modern electric options but don't have any specifics so please, bring it on! Much thanks! Mike in NorCal |
| wndsrfr |
May 8 2026, 07:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Maybe try this.....Wilwood Spot Brake....
you'll have to engineer mounting and cable routing....YMMV https://www.wilwood.com/Calipers/CaliperProd?itemno=120-1360 |
mlw914 '73 3.0l conversion suspension and parking breat suggestions May 8 2026, 05:37 PM
Ninja Ground Control rear springs/adjustable perches.
I ... May 8 2026, 06:03 PM
mlw914
I... May 8 2026, 08:58 PM
mlw914
you... May 8 2026, 08:59 PM
Steve Always check the how to forum
http://www.914world... May 8 2026, 08:28 PM
porschetub
http://www.914worl... May 9 2026, 12:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th May 2026 - 01:43 AM |
