> '73 3.0l conversion suspension and parking breat suggestions, Need advice from the World!
mlw914
post May 8 2026, 05:37 PM
Hello 914W,
I am going to update the suspension in my '73 914 6 conversion. It's got a 3.0l in it, dual PMO's, Cayman 4 piston calipers and 911 discs, 321 ignition, Patrick Motorsports conversion kit and front oil cooler kit, running 16" Ultralights to accommodate the brake rotors. Sway bars F & R as well.
I am doing some suspension upgrades and wanted suggestions on what suspension components you all would suggest. I am leaning towards Bilstein units but not sure.
I also wanted to know from those with more experience and knowledge regarding the parking brake setup. Obviously with the Cayman calipers I can't use the old system and its gone. What have you done or seen done to allow for an e brake? Don't get me wrong, my $7 Harbor Freight wheel chock is working great, just not an ideal setup. I have heard of compression lock systems and modern electric options but don't have any specifics so please, bring it on!
Much thanks!
Mike in NorCal
Steve
post May 8 2026, 08:28 PM
Always check the how to forum
http://www.914world.com/bbs2/index.php?showtopic=4909
I used the above info and early 911 shoe emergency brake. Make sure you weld an angle iron to the trailing arm to keep the shoes from braking loose during an emergency stop. There’s a reason why the factory did it with 911’s.
- Lo-Fi Version Time is now: 9th May 2026 - 01:43 AM
